Question about Ovens
What does code F7 mean on my acorn stair lift it is a superglide 120
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
I have a Kenmore built in oven, it doesn't work. There is a code F7. What could that mean?
Hello there:
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Oct 05, 2010 | Kenmore Ovens
F7 code
HELLO the F7 fault code means that you have opencircuit in the , ir thermocouple which is in the bottom element or the thermocouple for the top cc element,
May 02, 2010 | TurboChef TORNADO Electric Oven
Oven flashing F7 serial number is jgrp17bew288
F7 code
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced
Good luck and please rate 4 thumbs for the free answer
Mar 10, 2010 | GE Profile JT910SASS Electric Single Oven
F7 erroe code on my GE oven
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Sep 01, 2009 | GE Profile JTP56 Electric Double Oven
F7 fault code on the Jenn-air W30400W
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps .
Mar 04, 2009 | Ovens
Beeping and F7 when cleaning
F7 stuck keypad
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
My GE profile oven is giving me a code f7 and I can't clear it.  What does this mean?
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Best of luck!!
Thanks
Dec 02, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
54 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
