Question about Refrigerators
Freezer had food that spoiled in it. Cleaned inside and it has no smell. But terrible odor from back.
Wondering if there is a drain pan or tube that could need cleaning...
  • Refrigerators Master
  • 5,323 Answers
Yes there is a drain hole that may need to be cleared out using a tiny tube or wire of some sort but be very careful not to damage it.
see pics
Freezer had food that spoiled in it. Cleaned insid - 26409533-yftwsugzfqjbgscr3gu2igaf-2-0.jpg
26409533-yftwsugzfqjbgscr3gu2igaf-2-2.jpg Freezer had food that spoiled in it. Cleaned insid -" alt="26409533Freezer had food that spoiled in it. Cleaned insid - 26409533-yftwsugzfqjbgscr3gu2igaf-2-9.jpg"h_mi" />
Posted on Dec 24, 2016
The refrig has stinky smell after not opening it for two weeks without any spoiled food.
Is it a moldy odor or rotten food odor?
I suggest cleaning interior and then spraying with odor remover like: Nok Out Odor Eliminator and Sanitizer
Mar 20, 2016 | Refrigerators
We have a terrible odor from fridge side. Cleaned it 3 times..found nothing and odor persists Any suggestion? No odors when doors are closed
What does it smell like? Burnt plastic , mold , rotten food? Check gaskets and temp in fridge, food could be spoiling. It is tough to get serious odors out of fridges. Bleach, vinegar are good for killing odors. Check manufactures recommendations.
Apr 14, 2011 | Viking 42 in Built In Professional...
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
Smell developed in refrigerator, it is thoroughly clean
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first. It sometimes can be hard to find.
Jan 11, 2010 | Whirlpool GC5SHEXNS Side by Side...
What is causing a sewage odor from my Kenmore all refriderator?
At some time something spoiled inside the refrigerator, Every time your refrigerator defrost the smell and moisture collects inside the freezer and during defrost the moisture drains down a tube to a condensate collection tray where the fan from the condenser and heat from the compressor warm the liquid a d return it back to the air inside your home. The only way to stop this is to clean the freezer and fresh food compartment with a good cleaner like greased lightning or orange cleanser. Then you need to remove the rear panel of the freezer and spray the evaporator with a warm mixture of clorox and water and pour some into the condensate drain to disinfect the slime and smell that will remain there until killed by the warm clorox. You may also after done want to remove the cover over the compressor and wipe the condensate collector pans again with warm water and clorox. I know this will work and please don't rate me poorly like the last two people that I tried to help. This has been a bad day here for me and if you need any more tips please let me know, Thank You Sea Breeze
Jan 05, 2010 | Kenmore Refrigerators
Have alful odor in freezer and ref,had some things spoiled and lefted bad odor in freeer and smell went into ref tooked everything out and washed them out good, and put backing soda in but smell was still...
empty the unit and put a dish of charcoal in the frig and the freezer. Let it run for a week and see if that helps. Some odors will get into the plastic and insulation and cannot be removed.
Nov 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Terrible odor! Washed inside & still stinks! NOW what?
try coffee grounds in it. take and put it inside and leave it in for a while. also have you cleaned out the drain pan yet?
Mar 26, 2009 | Sub-Zero 632 / S
How to remove drain pan from compressor
the drain pan removal requires a sealed system repair to modify the type and new location of the replacement drain pan. this should get repaired by a certified refrigeration service technician.
Sep 18, 2017 | Kenmore Freezers
I have a kenmore freezer kinda new, my kids unplugged it, i came to find this problem on Dec 19, 2010 when i was cleaning and came about a heady smell around my freezer... ENTIRE frozen food went spoiled, the smell is unbareable. I discarded of it all, cleaned freezer inside very well... however, the smell remains inside freezer, a very foul odor.
I put arm & hammer baking soda, smell is still in it.
I put coffee grounds inside freezer, Today Dec 20 i bought activated charcoal & put it inside freezer. Question is: Do i need put water or alone and do i need to plug freezer...
May 21, 2008 | Cameras
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
