Question about Android Galaxy Ace
I need to take back off the phone to charge the battery
How long I need to keep plug the back up battery to use to charge my phone?
Most manufacturers recommend an overnite charge, but the power you require to recharge a phone is very minimal, so I would recomend at least 4 hours, unless the battery back up is new then you can charge your phone while charging the battery back up for the full 12 hrs.
Sep 10, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
I let my phone battery die yesterday and now when i try to charge it it says that the charger is attached; but when i try to charge it and turn it on it only goes to the main motorola screen with the...
yes of course, you need a new battery.
when you get this battery, also buy a universal charger.
do not insert the battery into the phone until you charge it for 3 hours with the universal charger.
after that the phone will work very fibenluis_14.jpgne.
Jan 27, 2011 | Motorola Mobility Clutch i465 Cell Phone
My motorola em30 ran out of charge. I plugged the charger in but it is not turning on. Nor is the charging light blinking what should i do?
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Sep 23, 2010 | Motorola Mobility MOTOROKR EM30 Cell Phone
Just charged my phone. now it won't reboot
when a phone won't turn on and blinks red light, it 's either the battery cell
First Charge the battery forlonger hours before using another battery to confirm
Take care.
Jul 05, 2010 | LG Dare VX9700 Cell Phone
My phone dosn't on and i have slso charged it
Jul 02, 2010 | LG KP501 Cell Phone
Battery drained for Bold 9000. It just died on me.
Get the battery charge charged and power on your phone back after the battery has been charged.
Use the charger that came with your bold 9000 to charge your phone, if it does not charge it, get a similar charger to charge your phone and power it on after charging, ou phone will continue to serve back as before.
But if the battery is not charging at all, it means the cells of the battery are dried, so you will need to get another battery on your phone.
Take care..
Apr 30, 2010 | RIM BlackBerry Bold 9000 Smartphone
IF I WILL CHARGE MY PHONE IN A FEW MINUTES IT SHOWS FULLY CHARGE
I'm not certain what your question is you made a statement more or less.
I do know that alot of cell phones will show that they are fully charged after minutes of charging, but then very quickly go back down to almost dead within an hour. This is because the phone is not actually fully charged. Most batterys need at least an hour minimum to be fully charged after its drained completely.
Post back if you need any further assistance. Thank you for choosing Fixya!
Jun 21, 2009 | Samsung SGH-D820 Cellular Phone
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
NO charge for the battery???
if battery has a charge then its charging --if not working when battery reattached then problem is with phone circuitry or plug connections
Jun 05, 2017 | Motorola Mobility MD41 for MD400 Series...
Android Galaxy Ace Logo
22 people viewed this question
Top Android Cell Phones Experts
john smith
Steve Sweetleaf
Steve Sweetleaf
Dakshinamurthy...
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
