Question about Garmin GPS
Garmin s 20 golf gps. Don't understand odometer readings. After 18 holes reading was 18.62. What does this mean?!
SOURCE: GPS wont boot up
Use with caution: This will delete your user data on the unit.
Try a reset:
  • Hold QUIT pressed when turning unit ON (will delete waypoints, routes and tracklogs)
(This worked for me when I had a similar problem.)
You could try a master reset;
  • Hold Zoom-OUT + QUIT + NAV and power ON. Hold keys for 10-12 seconds.
  • You lose all almanac and temperature compensation tables (it reconstructs itself but takes time - several hours)
  • Be patient - it will take HOURS for the unit to recover
Fair warning: I have not personally tried the master reset.
Posted on Dec 16, 2007
  • 104 Answers
SOURCE: Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
Posted on Apr 19, 2008
  • 109 Answers
SOURCE: odometer reads no bus
check bulkhead connecter for corrosion, cluster is your body controll module, losing signal to fuel pump module , and pcm, thios is a communication issue, volt meter wil help, back probe diagnostic connecter, pin 7, white wire, to see if signal is there, GOOD LUCK RDJRP
Posted on Aug 03, 2009
SOURCE: GPSMap 172c Can not read Garmin Data Card
I have the Sounder 178C. It will only work with 128 Mb Cards (or smaller). It does not work with the 256Mb Cards - says "Reading Card" forever.
Per Gramin, I had to buy the 128 Mb card and DVD map update. Then program the card with a USB data programmer to make it work.
Posted on Aug 12, 2009
SOURCE: 2000 buick odometer want light up cant read the
Odometer and shifter display does not light up
Posted on Nov 15, 2009
My Garmin S20 Approach golf gps watch says No Nearby Corses, what can I do, pete
read the user manual and install the maps for your area
Nov 26, 2017 | Garmin GPS
Please I'm still waiting for any solution What My 1995 c280 Mercedes Benz can not raise or fire beyond 20 odometer at idle, please what could be the problem
every one is having trouble trying to understand what you are saying
cannot fire or raise ----does that mean cannot accelerate the engine
beyond 20 odometer does that mean faster than 20 mph(klm ph)
or does it simply mean that it will not rev higher than 2000 rpm on the tachometer
a odometer reads speed and a tacho reads engine rpms
so you can see why no one is answering your question
it is confusing as to what you are saying
Sep 18, 2016 | 1995 Mercedes-Benz C-Class
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
GARMIN S1 GOLF GPS WATCH. I WOULD LIKE A LIST OF THE GOLF COURSES I CAN VISIT WITH MY GARMIN S1 WATCH. MY EMAIL: BRAEM.FRANCINE@SKYNET.BE THANK YOU
A list of the European golf courses for the Approach S1 Golf GPS watch can be found on Garmin's website.
http://www8.garmin.com/intosports/golfcourse.html
Sep 20, 2011 | Garmin GPS III Plus GPS Receiver
Golf logix 8
it should change by itself.
May 11, 2010 | Garmin Golf Logix GPS
My Golflogic reads the course but then I cannot scroll up to first hole.
Thats an easy one. Go into the course manager software where you load courses and press Help. Choose the option that says "how do i restore my unit" and then click restore. Plug in the GPS and turn it on. after it says its restored, turn it off, then back on (the gps, not the computer) and load your courses again. You should be good to go!
Aug 14, 2009 | Garmin Golf Logix GPS
Gmapprom.img file in Garmin Nuvi 205 corrupted
Connect the Nuvi to a PC with the USB cable, then hold the power button to ON position. It happend to me before and it worked.
Good luck
Mar 25, 2009 | Garmin nuvi 260W GPS Receiver
Can i down load golf courses to my garmin 260 i was told at the store this was possibble but i cant find any info on the garmin 260 gps on the garmin web site to tell me that i can do this. Or do i have to...
It's "possible" to use the 260 as a golf GPS unit, but it probably isn't going to be the golf tool the guy at the store promised.
1. There aren't any golf maps available for this unit, other than ones that have been created by users. 2. The 260 displays distance in feet or miles: is that a 5-iron? 3. The battery life is about 9 holes on the Nuvi series.
On the other hand, if you want to have a navigation GPS and also use it on the golf course, then you can check out the details on this website:
http://www.wideopenwest.com/~don_barger/nuvi-software.html
There are free maps for download and a web-based tool for creating your own golf maps.
Don
Mar 06, 2009 | Garmin n?vi 260 GPS
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
