Question about Simer Plumbing
My simer pump lights on - Simer Plumbing
How do I troubleshoot a Simer 3/4 hp submersible deep well pump
Check power at well head. then turn power off and disconnect wire nuts. check continuity on leads to motor should read about 500,000. Check each lead to ground for shorts.
Oct 14, 2014 | Simer 2873G Submersible 4" Well Pump,...
I have a Simer 2305 and the pump will run but does not when the water is low?
Pumps such as the Simer 2305 do not pump water totally down to ground level. They are designed so they do not suck up debris , sediment, etc, which can clog and ruin the pump. So if your pump leaves an inch or so of water, that is normal.
Mar 15, 2014 | Simer 2305 Geyser II 1-4 HP Submersible...
The flood light stays on and the pump will not work
Can anyone help? My Simer backup sump pump flood light is on continuously. All the rest of the lights seem to be working fine and the pump looks like it is in working order. When I toggle the lood light button it just gets brighter. tHANKS...SCOTT!
Jan 14, 2013 | Simer A5000 Ace In The Hole Battery Back...
How do I wire a Simer 2hp pump for 220v?
If it is capable of operating on 220, a diagram should be on the inside of the cover plate or the on the nameplate
May 29, 2010 | Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
What kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Simer Plumbing
Plumbing Logo
95 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Boyet Soriano
Boyet Soriano
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
