Question about Husqvarna Garden
Hello, To follow up on your answer,I put a new fuel filter in and it is getting fuel to the carb but seems like it is not getting fuel to the cylinder
  • Husqvarna Master
  • 2,535 Answers
Probably the Carburetor is dirty
Posted on Dec 23, 2016
Longjia 125cc raptor had problems with fuel leaking from the bottom of the carb and though the air filter. Just put a new carb on OK for a few day now doing the same any clues please
New carbs aren't known for leaking unless you had it open and altered some thing. A float can get stuck if you let it sit without using it. Should put stable in your tank and run it so thestable gets into the carbs.
Check above the carb for a gas leak from the gas hoses and check the gas tank. They may be running down onto the carb and just appears like the carbs leaking
Mar 07, 2016 | Motorcycles
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
I have a 83 plymouth reliant i have replace everything but the carb it seem to stop and go right when i hit about 35 and again when i hit 65 i cleaned the carb out still seems to do it put new fuel filter...
check for vacume leaks first. you stated that the carb was loose and you tightened it. you probably need to replace the gasket beneath it (thats why the carb seemed loose)
Feb 09, 2014 | 1983 Plymouth Reliant
Aprilia rs 125 won't start!!
right you done quite a bit, so whats left, fuel seems ok .. so ht lead ht cap, spark plugs dont always come with right gap, any leaks with airflow either side of carb, remember the filter often acts as a restrictor too. try the putting a small amount of fuel in cyclinder after cleaning plug, should atleast get a backfire, is choke setup ok, carb mix if not factory sealed is generally 1 and 3/4 turns out from tight,
Feb 13, 2013 | 2005 Aprilia RS 125
I have a John deere 316 with a onan and it will not run unless the choke is almost closed, I have checked the fuel flow and the compression and all seems good. What do you think is wrong?
hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Feb 22, 2012 | John Deere 420,1020,2010,2020,2510,2520...
I have a McCulloch I385L curved shaft grass trimmer. I replaced the fuel lines but it seems the inner diameter of lines is a bit smaller than the original. When I put the fuel filter back on, I twisted the...
Without the fuel filter, any small bit of grass or other small particals could easily clog a port in the carb. Don't worry however! Any small engine shop will have the filter in stock, and the fuel lines too! It will only cost a couple dollars. Just remove the two screws on the carb-to-motor. Disassemble the carb after disconnecting the thottle linkage, and blow out the ports with compressed air or carb cleaner. Sometimes a good hardware store has filters an lines too. The filter does NOT have to match your brand, just as long as it has one, and the lines don't really matter on an engine that small. Just make sure the lines are fuel rated! Good luck, and keep me posted!
Sep 30, 2011 | Garden
Starts up by sputters. not getting consistant gas
I don't think that is a gas filter. A gas filter is usually on the fuel line Try a new spark plug. Also the carb may be dirty.
Sep 19, 2009 | Garden
Engine runs like POP-POP-POP.Fuel solinoid?
Hi..my name is Keith...this is kind of a hard one to answer...when im not there...but i would suspect weak fuel..i would drain the tank and put fresh in and a new fuel filter..and if that dont help..then you might need a carb cleaning or overhaul..i hope this has helped..if not..write me back
Jun 28, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
53 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
