Question about Microwave Ovens
How do i move from alphabet to numbers on keypad
Jvm1650bh05 control panel
"F3" means you have a shorting membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X10961 and you can get order it from the Pros here for $106.61 (subject to change).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven at the link above.
Here is a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame. Be careful - the display is glass.
Some connectors on the relays have a lock:
Jun 09, 2013 | Microwave Ovens
Some of the numbers on the key pad are not working.
You have a failed membrane keypad. It's not uncommon for it to be intermittent or partially operable, too.
On some models, you have to peel off the old keypad and stick on a new one.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number (with any suffix) from the tag on the oven
here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you have to replace the frame, you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Jul 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Can not use any button of the panel like itis locked. model 721.80403402 serial# 506ta01558
Your membrane keypad has failed.
It is part number 383EW5A253B and you can get it the Pros here for $33.37. They can have it to you in a few days.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 07, 2011 | Kenmore Microwave Ovens
When pressing the buttons on the microwave it does not work. electricity works because "press clock" is showing.
I'm assuming that model number is HVM1540DM1WW?
On this model, the membrane keypad is not available as a separate part, so you could just order the control panel frame assembly which comes with a new keypad. In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X11012 (a.k.a. AP3993720) and you can get it from the Pros here for $55.06 plus shipping. They're our favorite supplier. You can find helpful exploded view diagrams and order other parts & accessories by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes. Then you unplug the keypad (as per the photo below) and move the circuit board into your frame. 34374fd.jpg Some connectors on the relays may have a lock: positivelock.jpg
May 24, 2011 | GE HVM1540DMBB Microwave Oven
We cannot set clock on mirowave model wmh1163xvb
Your actual model number from the tag on the oven will be WMH1163XVB0, WMH1163XVB1, or WMH1163XVB2.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
Here are the part numbers, depending on color:
Panel Assy, Control - Includes Lens and Membrane Switch
part number color
W10315771 Black
W10315772 White
W10315773 Stainless
W10315775 Universal Silver
You can find helpful exploded view diagrams and order parts by entering the part number or your full model number from the tag on the oven here.
May 23, 2011 | Whirlpool Microwave Ovens
I am getting a keypad shorted error msg and beeping. Can the keypad be easily replace (by me?)
On these models the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number with suffix from the tag on the oven here.
Apr 27, 2011 | GE Spacemaker JVM1740 Microwave Oven
Model-MH3184xpb-0 Lock symbol on keypad, continuos beeping. I unplugged power for now
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, you have a failed membrane keypad.
That is a simple do-it-yourself job, and the part is very affordable.
It is part number 8205376 and you can get it from the Pros here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven (as MH3184XPB0 with no dashes) here.
If photo does not appear, it is located here.
Jan 16, 2011 | Whirlpool Microwave Ovens
Kitchenaid microwave model KHMS155L, starts randomly for 3 minutes with "PAN" flashing on display screen, than locks up with "F-2" message on display screen
"F2" means you have a shorting membrane keypad. The "Pan Heat" key is shorting.
You can find helpful exploded view diagrams and order parts by entering your full model number* from the tag on the oven here.
Some connectors may have a lock:
* The exact part number you need will depend on your exact model number. Models in that series are shown below:
KHMS155LBL0
KHMS155LBL1
KHMS155LBL2
KHMS155LBL3
KHMS155LBT0
KHMS155LBT1
KHMS155LBT2
KHMS155LBT3
KHMS155LSS0
KHMS155LSS1
KHMS155LSS2
KHMS155LSS3
KHMS155LSS4
KHMS155LWH0
KHMS155LWH1
KHMS155LWH2
KHMS155LWH3
Dec 17, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Keypad is inoperative
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
You can find handy exploded views and get part numbers by entering your full model number at the Sears Parts Site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Once you have the Sears part number, you can usually get parts cheaper here.
If you might be interested in having us so the work for you, we charge $39.95.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 08, 2009 | Kenmore 63792 Microwave Oven
Kenmore microwave model number 401.80084700 Displaying -SE-/-5E-
-SE- error means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
There are three ways you can get it fixed:
DE34-00178X SWITCH MEMBRANE $20.30
ref#53 membrane keypad
take yours off as in the video at our site, peel the old keypad off as in this handy guide with pictures , clean the surface, stick on the new keypad
order by part number here
(We can do this job for you for a total of $70.25, but as you can see, the other two options are more practical and economical)
DE94-01647A ASY CONTROL PANEL $39.01
ref#66 control panel frame with keypad
take yours off as in the video at our site, disconnect the keypad strip as shown here, move your circuit board to the new frame, reinstall
DE94-01648A ASY CONTROL, BOX $58.12
ref#59 complete control panel assembly with frame, keypad and circuit board
take yours off as in the video at our site, then install the new one
If these parts are not in stock, they should be available in about a week or so.
Aug 06, 2009 | Kenmore Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
