Question about Navman S35 Handheld GPS Receiver
Navman s35 won't connect to satellite
I've tried to reset, just keeps saying unable to connect to satellite. i've only had it 4 months,.
    Brigadier General:
  • 3,513 Answers
Thank You for contacting Fixya.com
Make Sure the GPS has a good, clear view of the sky. “Clear” does not need to be sunny. Overcast skies have no noticeable impact on GPS performance. But buildings and trees do. So take the GPS outside where you have the biggest sky view as you can.
Next, wait for the GPS to acquire a signal. If this is the first time you have used it, expect it to take up to 20 minutes to find a signal. Most often it will take less, but prepare for 20 minute. Now for an important step… Once it has found your location, let it continue to sit there for about 30 minutes.
While the GPS is turned on with a signal, it is downloading “almanac” data from the satellites. This information will help it find the satellites much, much faster in the future because it will be better able to predict where to listen for the satellites.
It is important that while the GPS is acquiring a signal that you not move the GPS. A few feet is fine, however if you start driving with the GPS before it has locked into a signal, it will take much, much longer to acquire a signal, if it finds one at all.
Other Signal Impacts Rural areas don’t make a difference like they do with devices that rely on terrestrial signals like mobile phones. The GPS system was designed to work nearly any place on Earth. In fact, urban areas with tall buildings nearby are the toughest challenges for GPS systems.
GPS manufacturers are constantly working on ways to improve their products, and acquiring GPS reception is no exception. So check if there are any software updates available for your GPS. Some GPS manufacturers like TomTom also offer updates on a periodic basis that help it with that “almanac” data. TomTom calls this “QuickFix” updates and you can download them to your GPS to help it find a signal faster.
Some types of windshields (specifically athermic windshields) don’t allow the GPS signal to pass through as easily. In this case, an external antenna can help if one is available for your GPS. If you live in urban area with lots of tall buildings, an external antenna can help in that situation as well.
Good Luck and God Bless
Posted on Jul 21, 2009
Will not fire up a gps signal
Most GPS systems require a first time boot-up where they scan all registered satellites to determine where in the world they are and what satellites to concentrate their navigational efforts on. Try charging the GPS up entirely, and then doing a hard reset of the system (either by navigating to the hard reset in software or by pressing the tiny reset button usually located on GPS units), and then taking the system out under the open sky and letting it run for half an hour or so, making sure it is running in navigation mode (as opposed to setup or media mode). Once it locks properly onto a small subset of satellites, it should not have much difficulty.
If you continue having problems, check to be certain you are running the latest software on the device which can make a big difference. The latest software for the 520 is here:
http://www.navman.com/Navman/Templates/standardcontent____4407.aspx
Good luck...
Nov 21, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
The screen has frozen and it cannot find a signal.
try this: 1. Connect your device to the computer 2. Make a backup of your addresses and favorites if you wish 3. In File Explorer, right click on the device (removable drive) >> Format 4. Start the Desktop 5. Go to Tools >> Reinstall the software 6. Go to Tools >> Recover Keys 7. You can now reinstall the maps from the Maps tab. 8. Go to Voice Transfer and re-install the voice files
Jan 16, 2011 | Navman S35 Handheld GPS Receiver
I have a Navman s35 but these days it cannot receive a GPS signal. I heard some programs might have a problem like my GPS but I am not sure. There is the problem anywhere like outdoor, no cloud in sunny...
I had the same fault which corrected itself after a couple of months left in a drawer. I suspect it reset it self after the battery went completely flat. You could try removing the battery switching on and off a few times to remove any power still in capacitors and then refit battery. Then Reset
Sep 29, 2010 | Navman S35 Handheld GPS Receiver
Have a navman s35 and don't have navdesk software disc. how do I obtain disc or download software? thank you.
Its possible that you need any patch, with the devices connected, try HERE.
Or, contact in this LINK.
Oct 15, 2009 | GPS
Navman s35 keeps saying acquiring gps signnal can anybody help
Are you in an area that it can pick up the satellite, like outdoors with no trees overhead, etc.? If so, try external antenna if possible.
Jun 28, 2009 | Navman S35 Handheld GPS Receiver
Cannot find satellite.
Hi have you tried doing a factory reset.I had the same on a lowrance and after do the reset it worked fine.
Apr 05, 2009 | GPS
"Searching for Satelite" - unable to find
10-15 minutes is normal.
Did you take it outside? GPS doesn't work indoors. Try in an open field, no trees. Should lock in a few minutes. I always do the following: i key in the destination address at home, then put it under 'favourites". When i start driving, i put the unit in my car and look up the recently added favourite. The unit then has enough time to lock on to the satellites.
Jan 07, 2008 | Navman F20 GPS Receiver
Navman S35 Handheld GPS Receiver Logo
465 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
