Question about Kenmore Kitchen Ranges
SOURCE: F90 Err on Kenmore Elite
the F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Good Luck
Posted on Dec 30, 2008
SOURCE: F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 10, 2009
SOURCE: I have kenmore elite gas range 790 series getting
The F93 shows that the Maximum oven door lock time has been exceeded.
Turn off the range and turn off the AC power and wait for up to 10 mins. The door should reopen. Turn on the AC power ans see if the error persists. If it does then check the following.
1. Check the wiring between EOC & Lock Motor Micro Switch.
2. Replace the Motor Door Latch assembly if necessary.
3. Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Posted on Nov 12, 2009
SOURCE: What does the errror code F90 mean?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
SOURCE: F90 error code Kenmore elite
The F90 error code is a door lock code. There are a couple of steps that you can take to try and clear the code. Do the following:
1) Unplug the range and wait for one minute.
2) Plug the range back in and turn it on.
3) Hold the door in and start a self clean cycle.
4) Wait for 2 minutes and then cancel the self clean cycle.
5) Do not let the door go until the door lock light goes out.
If that procedure does not clear the error code then you may have to get a Kenmore repair tech to take a look at the unit. There are a number of electronic fixes mentioned in their repair manual, but you would have to have the proper tools and training to run through those procedures. If there is any warranty left on the unit you can of course have the repair paid for. If not, then any repair shop should be able to give you a rough estimate on the cost of repair.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
Posted on Feb 17, 2011
I appreciate your post, Haozhen!
From what you have described your Frigidaire range is displaying an error code of "F90" and your oven will not work. The "F90" error code stands for maximum door unlock time exceeded. This could be a problem with your door latch assembly or EOC (Electronic Oven Control). You would need to disassemble your range and test each component to assure it is providing an accurate electrical reading. This is not a simple DIY job and I would recommend having a professional technician out to perform a proper diagnosis and repair. Hopefully this information is helpful. -Matt
May 06, 2015 | Frigidaire Kitchen Ranges
Aug 27, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Jan 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Dec 16, 2008 | Ovens
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Apr 11, 2018 | Kenmore Kitchen Ranges
29 people viewed this question
