Question about Viking Ovens
The outside glass on my Viking oven (VESO5302SS) shattered. Need help figuring out how to remove the piece that holds the glass is place.
I purchased the glass already (PE060090). I've taken the door off and completely apart so that all that's left is the front door panel that holds the glass. But the thin metal strip that surrounds the glass and holds it in place (Viking calls it a "window holder" L20014077) appears to be glued on or held in place with sticky strips on the top and bottom. How do I get this "window holder" frame off so that the replacement glass can be put into place? And then how would I re-attach that same frame? Thanks!
4 Suggested Answers
  • 13433 Answers
SOURCE: Microwave door glass replacement
as the other experts have noted, the whole front door needs to be replaced.
Posted on Jun 16, 2008
  • 833 Answers
SOURCE: Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
SOURCE: I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Posted on Jan 15, 2009
Re assembling the door....
As a general rule of thumb, oven door glass assemblies are not intended to be removed for "cleaning" or some such procedure. Go to and enter RBS275PDB8. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool oven disassembly video which may help.
Aug 15, 2016 | Whirlpool RBS275PD Electric Single Oven
yes u can refit it normally.but do it carefully.need more help regarding this let me know .
Jun 16, 2008 | Ovens
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
How do we replace the shattered inner glass of the oven?
Most oven will have a series of screws that hold the door halves together and you would need remove those so that you can gain access to the glass panel. Some doors only have two screws that also hold the door handle on and you would have to remove just those to gain the access you need. Hope this helps!
Aug 11, 2015 | Combi Ovens
Replace inner glass on kitchen aid wall oven
This can be quite a difficult issue to deal with.. This is really a job for a pro technician, honestly. But if you should choose to try it. Remove the oven door from machine, by opening door slightly and looking at hinges you should be able to be able to slide a small arm on the hinge that locks the hinge and stops the door from closing. You then hold door and move toward closing it and lever the hinges out of their space and carefully place door on floor. Then you have to disassemble the door and remove glass. The video below IS NOT EXACT but will help you with what your up against.
Feb 02, 2015 | Ovens
Oven door glass shattered
What was the weather outside?
Feb 03, 2014 | Miele Ovens
The outer oven door glass shattered suddenly how do I change it?
I depends on how old your oven is. If you're lucky you may be able to get a replacement glass. If not take some measurements and see a glass supplier. You will need a piece of tempered glass.
Feb 07, 2011 | Ovens
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 | Ovens
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Ovens Logo
27 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
