Question about Sony Car Audio & Video
  • leone C
    leone C Dec 22, 2016
    Of your bridging your subsake sure your amp is on low pass not full range
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 123 Answers
Your grounding the amplifier chassis, isolate the amp from the car and make sure the remote is not going to the power antena or illumination wires on the bavk of your head unit, remote wire/amp , or eq , sounds like a grounding a power wire..
Posted on Dec 22, 2016
4 Suggested Answers
  • 22 Answers
SOURCE: no sound from my amp
the kight is red because it isnt wired properly, try connecting a thicker ground wire then double check the fuse in amp plus in the power supply cable
Posted on Mar 27, 2009
  • 155 Answers
SOURCE: my sony xplod 1200 whatt amps red light keeps comi...
check your ohm load on the sub and see if your amp can do the same, That is why every time it shuts off into protection mode. Check your gain level on the amp to this is not a volume knob for your amp, It is to get both the amp and cd player on the same page. Hope this was helpfull
Posted on May 27, 2010
  • 256 Answers
SOURCE: I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
Posted on Jun 09, 2010
Green light comes on for a sec the red light comes on,1200 watt sony xplod amp 10'' Orion sub,I think the subs right around 3000 watts. What's wrong?:(
Your Sony Xplod amplifier turns on briefly (green light) then possibly senses a mismatch between the nominal output impedance of the amplifier and impedance of your Orion sub and goes into protect mode (red light) to prevent internal damage.
Jul 19, 2014 | Car Audio & Video
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
When I turn off my truck and the blue lights on, it turns off but when the radios on and I turn the truck off the radio does turn off unless I hit the off button! Help sony xplod cdx-gt640
do you mean the blue light on the power button? it sounds like your radio's switched power input (usually red) is hooked up to a 12 volt constant source.
Feb 22, 2010 | Sony XPlod CD Player w/MP3 Playback...
Witch one is the power wire on a sony xplod cdx-ca600x
Switched power is Red
Constant power is Yellow
CLICK HERE for your Owners manual.
THanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 22, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
No sound from my amp
the red light usally means its over heating and turns off the amp as a protection
Mar 26, 2009 | Sony Xplod 500W Bridgeable Multichannel...
Wiring problem
Power wires are as follows -
Red = Switched power (ACC)
Yellow = Constant power
Black = Ground
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My sony xplod 1000w xm-1652z doesnt work anymore
First off, according to the manual, the protect light should be green. That's normal operation. If it is red, that's a problem.
If it does go red, disconnect all of the wiring to the amp except the +12V and ground. Short the remote connection to the +12V to force the amp on. If the protect light still lights red, the issue is inside the amp and will need repair. If the issue goes away, try reconnecting one wire at a time until the protect light goes red again.
Mar 23, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
56 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
