Question about Sony Car Audio & Video
MY Sony XPLOD BOOM BOX CFDG 700CP DOES NOT POWER UP
2 Suggested Answers
  • 114 Answers
SOURCE: THE POWER BUTTON ON MY SONY XPLOD CFDG 700CP DOES NOT STAY ON. IT INITALLY GOES TO RED BUT DOES NOT STAY ON
Your grounding the amplifier chassis, isolate the amp from the car and make sure the remote is not going to the power antena or illumination wires on the bavk of your head unit, remote wire/amp , or eq , sounds like a grounding a power wire..
Posted on Dec 22, 2016
Where can i fine antenna replacement for sony xplod cfd-g505
Go on line to the SONY website and request the parts list for your boombox. THen order it!
Jan 01, 2013 | Sony CFD G505 Boombox
Can i have box dimentions for my 12" xplod sub
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
Jun 04, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
When I put a cd into my boom box the display reads "no disc". can you help? Everything else works great so I'd really like to fix it if I can. Thanks
LASERS ARE LIKE THE OLD RECORD NEEDLES THEY ONLY HAVE A LIMITED LIFE AND GET WEAKER WITH AGE HOW OLD IS THE UNIT ANDARE YOU PLAYING BURNT CDS IF SO BUY BETTER BLANKS AND MAKE SURE WHEN YOU BURN YOU DO A RED BOOK BURN.
Nov 03, 2009 | Sony Xplod CD/Cassette Boombox with AM/FM...
Specs for box
Download the manual for the woofer from the Sony site. It will give you the volume needed for the sub.
If you need help constructing the enclosure, there are several applets on the following page:
Click HERE.
Jul 19, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xm1652z amp problems
it sounds like you have the high lvl inputs on the amp hooked up instead of the rca's. this will cause the boominess for a few seconds when the amp is on and right when you turn it off
Jul 11, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Car Audio & Video Logo
46 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
