Question about Tablets & eReaders
A certain Application updated, now my tablet doesn't show my downloaded videos. Only audio? Any ideas as to what might have happened?
  • kakima Dec 22, 2016
    Hi John Spannbauer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model tablet? What was the app?
Why does my tablet shut off automatically in the middle of a program? It does this often. I have reset it twice, and the dsame thing continues.
Is it always the same program that this happens with, or any program you are running? If it only happens when running one certain application, then I would tend to think it is something with the app. If it happens when running any application, then I would expect it is a hardware issue. In that case, and as you have already reset it multiple times, I would suggest contacting the manufacturer directly.
I post on behalf of HP.
Jul 29, 2015 | Tablets & eReaders
Why did my Ipad 3 stop playing certain video clips on Facebook?
Have you checked to see if your ipad requires any updates. Sometimes these need to be updated and this may solve the issue. If this is not the case I am afraid I cannot help.
Aug 10, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How do I fix this: Apps were downloaded but Icons don't show and I can't open them?
Pull a downward one finger swipe on the springboard to initiate spotlight. Type the application name to see if the global prefs log has recorded that you have the application installed with a valid owner code signature.
if applications were installed with another appleID and require an update to execute but you are signed into the AppStore with a different appleID, the situation you are describing can occur.
Aug 04, 2014 | Apple iPad Tablets & eReaders
My screen only shows in horizontal not vertical since the most current iOS7 update.
If this issue only happens in certain apps, then it's probably because the app has not been updated to support the different screen orientations.
Also check the General settings and make sure you have not set the lock setting that keeps the screen from rotating.
If all else fails, you should contact Apple support to have your device checked out.
Hope that helps!
Oct 28, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Downloading series onto tablet
Just download the free VLC app on http://www.videolan.org to your tablet then upload the video files with this application to your tablet. It also works with subtitles and alternative audio. 11_17_2013_3_04_35_am.png
Jul 28, 2013 | Tablets & eReaders
Update problem with lg v900
there are no official update for this Tablet. LG doesn't make any update for LG V900. Before, I also keep asking the LG customer service a few times until they answer "No UpDate"...:(
Jul 24, 2012 | LG Optimus Pad V900 32GB
PROBLEM WITH TABLET CRUZ READER R101
To update the firmware you can follow the directions here http://www.ehow.com/how_7890482_update-cruz-reader-firmware.html
I used a similar method when I had my Cruz Reader R101. This process is called "side-loading"
You will have to download a file to your computer (not your tablet), remove the SD media card from your cruz, then transfer the downloaded file from your computer to it, then replace the SD card to your cruz.
Also you can download the user manual here http://www.retrevo.com/support/Velocity-R101-Tablets-manual/id/23894dj696/t/2/ which shows how to remove the card, and this is a great reference to keep on your reader. For example, page 14 shows how to transfer files to and from your reader. Good luck!
Jul 21, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
On my pandigital nivek 9inch the application browser(process com.android.browser) has stopped unexpectedly and it says try again, but when you try again it still doesn't work
I also had this problem. What I did was hooked my pandigital up to my computer and put videos on there that would take up alot of room. After I unplugged it I got a message saying that my memory was low. I clicked on the message and it showed me all the default applications instead of the applications I download. I clicked on my browser and pressed force stop and clear cache and it had worked fine. If you dont feel like doing all that work I suggest you download another browser such as Opera Mini or Dolphin Browser mini.
Dec 24, 2011 | Tablets & eReaders
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Tablets & eReaders Logo
23 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
