Question about Ovens
I need wiring diagram for control board 342145 on kenmore model 911.3018812 oven. Do the letters by the terminals have anything to do with the colors of wire to plug into it?
Powerman
  • 68 Answers
SOURCE: Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Posted on Nov 22, 2007
Powerman
  • 68 Answers
SOURCE: Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Posted on Oct 31, 2008
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
SOURCE: Electric Diagram for Kenmore Model 790
I have a Kenmore Model 790.91062601 and it has stop heating. None of the burners or the oven will heat. Any solutions
Posted on Aug 30, 2009
  • 250 Answers
SOURCE: Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Posted on Jan 26, 2010
Replaced bake element in Kenmore oven model number **********0
Hello;
My name is Peter. I am a retired field service appliance technician.
You did not provide a oven model number which should be on a label on the face of the oven when you open the door or on the side of the door. Locate the model number for later.
You need to go to a Lowe's or home depot store and spend $25.00 on a multi-meter. Read the manual and you will be able to know for fact what parts are good or bad. This is a good tool that you need for all of your appliances. I guess you spent about $70.00 or more for the element.
You replace a element when you notice a crack or a meter Ohm reading of OL.
There are three components beside the main control board (Which this is rare) that are the cause of failure.
1.) The element - which you have already replaced.
2.) The oven thermocouple - Which regulates the oven temperature. You can purchase this over the internet for about $25.00. Used parts are good. You need a multi-meter to check if the thermocouple is good or bad.
3.) The oven control board - If the two above components are good, then this is your problem. The oven control board is separate from your main control board. Depending on your model, your can purchase this control board from Sears for $200.00 - $270.00. Or you can go into the following website, put in your model number where you will get diagrams and part numbers, search the internet with the part number for best price.
Water Filters Lawn Garden Appliance Parts
Mar 30, 2016 | Kenmore Ovens
I need a wiring schematic for a Kenmore model 79040522400 wall oven . Control panel the five wire that hookup on side for broil, bake, etc
diagrams are inside the control panel, usually in an envelope to the left or right side of center. If not there, look on the top or rear panels as they may be adhered to either of those. Worst case is someone took them from the unit during service in the past and never replaced them. Last option is to look online at sears parts direct. They show the diagram, but it is not clear.
Jan 26, 2015 | Kenmore Ovens
Fan motor is slowing down and not keeping the desired temperature
The circuit diagram for the standard control model shows the blower has a two-speed motor, connected directly to the power line in "Cool" mode, or connected to the temperature control in "Cook" mode. When the blower slows down during cooking, switch it temporarily to "Cool" mode. If it goes to normal speed, the problem is with the mode switch contacts or the wiring terminals between the fan mode switch and the temperature control board, or the control board itself.
If the speed does not change, check the wiring terminals at the speed switch common terminal (I assume your problem occurs in both low and high speeds). If you find tarnished, loose, or burned terminals, clean, repair or replace as needed. (In extreme cases, a loose terminal will cause the wire to overheat, damaging the insulation, oxidizing the terminal and causing a high-resistance condition that will reduce the voltage available to the motor.) If the connections are all good, the motor bearings are probably getting sticky at high temperatures. Let the oven get hot enough for the blower to slow down, then shut it off and check the blower bearings while wearing oven mitts.
May 12, 2014 | Southbend SLGS-22SC Gas Double Oven
Small back elements only work on high settings
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 11, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
My control panel on a whirlpool oven rbd305pds15 now shows E6 F2 codes and I am not sure what they mean??? How do I fix this?
An F2 E6 error means that there is a problem with the keypad. Make sure that the keypad wire is firmly connected to the control board. Then press Cancel. If the error returns in 60 seconds, you need to replace the keypad. With some Whirlpool ovens the keypad and control board are a single unit and you will need to replace the entire assembly.
For this oven, it seems that the control panel assembly is available here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139596&diagram_id=28216054 (On the Control Panel diagram, there are three listed - pick the one that matches your oven color.) The price depends on the color option.
I hope this helps.
Jul 08, 2011 | Ovens
Lower element stop working, wouldn't heat past 140 degrees, then tried to used the stove top and those stop working completely. Is there a safety feature to cuts the stove top off? Also is the element...
Hi and welcome to FixYa, I am Kelly
This sounds as if you have lost half of the power to your Oven. It can be from a partially tripped main Circuit Breaker for the Oven or an internal wiring problem of a burned wire or terminal. It can also be the range control itself. but I doubt that since you said the burners also do not work (depending on model) If you have separate burner controls definatly NOT the range control.
If you pass your model number we can better help you. The fact that the lower element is only reaching 140 degrees is pretty much indicating that your oven is operating on 110V vs 220V. The causes again are input power, oven wiring or the range control.
Reset the Oven CB and check BOTH ends of the range cord (if you have one) for signs of hot terminals. For a direct connection look closely at the terminal board where the house wiring connected to the oven.
With a MODEL number I can look at manuals and diagrams to better assist you. Please pass that complete MODEL number in any future responses. Most any future response I provide after I get a MODEL number will involve using a meter and opening the oven to troubleshoot.
Thanks for choosing FixYa,
Kelly
Feb 23, 2011 | Maytag Ovens
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
I was gettin a F5 error andnow i get a F3 error
These are both problems with you Temperature sensor and circuit.
I would check the sensor first. You should have close to 1100 ohms. If this checks out good and wiring looks good the relay is integrated into the board so you would need to replace the control. The info below was taken from www.appliancehelponline.com You can also find diagrams there to show you what these parts look like.
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control.
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
F5
Relay safety circuit failure
· Check oven temperature sensor circuit for intermittent high resistance.
· Check lock circuit
· Press Clear/Off and reprogram control. If code reappears, replace control
Note: If all above check OK the F5 code can be a result of a momentary loss of power (Do NOT replace control or lock, check lock circuit)
Mar 21, 2010 | GE JTP15 Electric Single Oven
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
