How can I run portable DVD through tv? The cable supplied with DVDs has 3 AV plugs but tv only 2 male fittings
SOURCE: Trying to watch DVD played on portable Insignia player on the TV
If you hear a noise, when triying to read DVD, I am shure I´ts teh engine malfunktion.
you must get the mechanisiam or take this to a service.
I´ts very difficult for lenses to get brocken.
Posted on Jul 02, 2009
SOURCE: no matter what tv i plug this console into, it does not work
my n64 part is not working the part u plug n the tv
Posted on Oct 26, 2009
  • 4 Answers
SOURCE: INeed av cable for Trutech 7? Dual-Screen Portable DVD Player
Okay, I just had to replace both the DC power and a/v cable for this Trutech DVD player and here is the solution. The a/v cable is a 4 pole 3.5mm cable, which I found here: http://www.techcables.com/6-ft-3-5mm-4-pole-mini-av-to-mini-av-camcorder-a-v-cable-p-36.html I went to Radio Shack and bought the coax style DC power plug ends which were size B and soldered new ends onto the old power cable, tip to tip, sleeve to sleeve: http://www.radioshack.com/product/index.jsp?productId=2102598
Posted on Dec 14, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: dvd screen comes up on TV but dvd player says "disc error".
unplug the pwr cord from dvd for 5-10 min..plug back into outlet..make sure the av cable is connected white-white yellow-yellow red-red...now press play on the dvd
feel free to rate help
Posted on Jul 04, 2010
bronk50
  • 27725 Answers
SOURCE: I need a new cable
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Posted on Jul 19, 2011
We have purchased a Samsung 55" Smart TV. We have it set up and working with Foxtel connected via the supplied fittings. How do we connect the DVD player?
The usual way is to connect it via a HDMI cable, for which the TV should have 2 or 3 input ports. You then select this HDMI as input on the TV to see a DVD playing.
Get a "high speed" HDMI cable. Some will say there is no difference between any HDMI cables, but they did see fit to increase the bandwidth in these cables for Blu-Ray DVDs.
Dec 27, 2016 | Samsung Televison & Video
What kind of AV cable is used for the Kawasaki PVS10921 Portable DVD Player? I have the player itself, but lost the AV cable to connect the player to my TV, and I've been unsuccessful in my attempts to...
The cable supplied with the player splits the audio feed from a single audio jack to dual RCA jacks for connection to a standard VCR or TV. The video appears to be a straight RCA to RCA type connection where a standard cable can be used.
See the users manual here:
http://www.1800customersupport.com/productdocuments/PVS10921%20Product%20Manual.pdf
Dan
Aug 26, 2010 | kawasaki PVS-10921 Portable DVD Player
No Picture
Hi And Welcome to Fixyah,
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task.
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
May 14, 2010 | Pinnacle Dazzle DVD Recorder
I am wanting to connect my portable wharfdale dvd player to a tv. where can i get the right connection cable. thanks
Usually somewhere like radio Shack will have those cables, they are called AV, Audio Visual Cables, You need 3 Cables, with "Male Jacks" at both ends, usually Red & White, (The Audio), & Yellow, (Video). They connect color to color at each end, and on the TV you select "Aux", "Extern", but NOT a channel. If you have "Component Video, then you will need a set of 3 & 2 cables, (5 all together) Blue, Red, Green, ALL Video, & White & Red, Audio. you select the "Input" on the TV the same as for AV. So with AV, you use 3 cables, with Component, you use 5. If HDMI you need a single HDMI cable. cables.
Feb 21, 2010 | Televison & Video
How do you connect the portable dvd player to your big screen tv?
Look on the side of the dvd player you should see a connector that says AV Out or Video Out, you will need a wire that plugs into that which depeding on the model of dvd player can be either the Red / White/ Yellow Phono Plug Leads or a Lead which has the Red / White/ Yellow Phono Plugs and at the other end what appears to be a headphone jack connector with 3 black bands on it indicating that its a 4 Pole Video output cable, then you plug the Phono Plugs into the Phono Sockets on your tv, using your Tv remote you will need to select which input you got the dvd player plugged into this will either be called
Source Or Input Or AV 1-2-3 ect.
jon
Aug 11, 2009 | Initial Televison & Video
Connect PS2 to Portable DVD Player?
I've done this before, i had to buy double female R.C.A. connectors (3) of them sold individually if I remember correctly, and then proceed to connect the 3 "male" ends from the PS2 cables to the 3 double "female" connectors i bought (best buy, meijer, radio shack, etc.) and then connect the 3 "male" ends of the R.C.A. cables that came supplied with my portable DVD player to the other end of the 3 "female" connectors, and finally connected the other end of the (DVD supplied) cable into the portable DVD player. hope this helps, and i apologize if it sounds a bit confusing, just trying to be as thorough (i have no idea if i spelled that right) as possible. Keep me posted if this helps!
May 31, 2009 | Polaroid PDV 0707N Portable DVD Player
AV input from a game console
try using the RED, YELLOW , and White connections in different holes soemtiems they get crazy and swap video yellow, to video red instead of video being yellow on both ends, figure out which one is the video cable by trying all 3 , to all 3 connections on your tv, while both devices are on
Dec 03, 2008 | Philips Magnavox MPD845
I have the cord to hook up the portable to a tv.
Yellow-White and Red will hook to AV Input in TV and you can find same colors female pins at back of TV.
Nov 28, 2008 | Sony DVP-FX810 Portable DVD Player
Games
try going to radio shack and asking someone who works there to help find a AV female to AV input chord.
hook up the device that has a male AV out plug to the AV female plug and hhok it up to your DVD player
Dec 24, 2007 | Mintek MDP-1770 Portable DVD Player
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
