Is a 56000 btu janitrol heater to big to put in a 22x22 garage?
KW to BTu's
To convert KW to BTU use the following:
1KW= 3412.142 BTU/ hr
Hope this helps.
Bob
Jan 17, 2014 | Intertherm 56000 Btu Gas Furnace
How big of a breaker do i need to install for a 45000ng mr heater big maxx?
It looks like a 15 amp breaker would be fine, here is the spec sheet
http://shopfnc.com/pdffiles/mhu45spec.pdf
As you can see the unit only pulls 3 amps.
Hope this helps
Nov 14, 2010 | Mr. Heater Natural Gas Garage Heater -...
Mr. Heater Natural Gas Garage Heater - 45,000 BTU. Power 120 volt and 24 volt good. Thermostat calling for heat, but nothing happening??
Check for a fuse either in-line or on the circuit board. There should be 24 volts going to the thermostat. If not, you have either a bad transformer or a bad thermostat wire. Jump out the terminals that the thermostat wires are connected to. This should force the unit to fire. If not, bad circuit board.
Dec 23, 2009 | Mr. Heater Natural Gas Garage Heater -...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
