Question about Cell Phones
Activate this replacement phone abd deposit 500 minutes
LG tracfone 2/16/15 420 minutes from old tracfone were nottransfered. tel#3212897283 Ser.014303004933018 SIM#8901260822192586314.transf.confirmation#1107560879.
Fixya is a help site run by a loose-knit group of volunteers. Fixya has no responsibility for your missing air-time. I suggest you contact your carrier.
Feb 17, 2015 | LG Cell Phones
2010 sportsman 500 hd runs then dies turns over won't start
My opinion, it's running rich and letting it idle for 5 minutes doesn't help. Whether it's carbed or EFI, when the machine is cold, it needs more fuel. As engine temperature increases, it doesn't need as much fuel, and the carbon that started building up on the plug is burned back off. When a machine isn't ran for very long, carbon deposits continue to build on the plug. The carb itself may need to be rejetted/adjusted, it it's running rich,
Aug 12, 2014 | Polaris 2010 Sportsman 500 H.O
Check my paypal account balance
PayPal is an online money transferring site used by many around the world to make purchases and payments online.
Typically, a PayPal account is linked to one's checking account, which allows you quickly make deposits and withdrawals.
Part of PayPal's popularity draws from the fact that the site is secure and very easy to use. Checking all recent activity and transactions on a PayPal account are simple and take a matter of minutes to look through.
Go to paypal.com and enter your email address and password into the box on the left, then hit "Log In".
Look at your account balance in the center of the screen. Recent activity for the past 7 days will be displayed underneath under "My Recent Activity".
Look through all these transactions to make sure there are no errors. Select "View all of my transactions" on the right hand side to see a list of all deposits, withdrawals, and transfers made to and from your account.
These transactions are in chronological order starting with the most recent.
Skim through these transactions to make sure all the charges and actions were made and authorized by you.
Hit the "Contact us" link on the right hand side to ask questions or send concerns to the PayPal staff through email or by phone.
Nov 22, 2013 | Computers & Internet
A sum of Rs 500 deposited in a bank which pays interest at the rate of 6 percent compounded semi anually. What will be the value of the deposit in 18 months? ...
@ 6mo = 500 x 6/100 + 500 = 530
@12mo = 530 x 6/100 + 530 = 561.80
@ 18mo = 561.80 x 6/100 + 561.80 = 595.508 ~ 595.51 (rounded)
Jan 16, 2011 | Computers & Internet
I want to activate my international calling but it needs a call barring password
You can only obtain this from your network provider. Tell them that you want "roaming" activated on your phone. Note that it isn't always available on all calling plans and some network providers insist on a deposit or a credit check before activating the facility.
If you're a regular paying long-standing customer then it's not usually an issue.
Sep 29, 2010 | Cell Phones
Dear sir, I have received a msg from my mob no.9213961710 dt on 17.03.2010 I have won award 600.000.00 GBP pounds in UK 2010 T...mobile claim tothis email tmobilepro@live.com iclaim to them and they...
yes you can refund it,!becaous you have right to fefund your money,and it depends also the terms and condtion. and you need to report if didnt refund it .
Apr 12, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
I need an MEP code for a blackberry 8900
Go to uniquephones.com and use the promo code crackberry. The unlock code will cost you $10 abd you'll have it in 5 minutes. I've unlocked 3 phones with them.
Rate it.
Mar 02, 2010 | HTC Tilt 8900 Smartphone
I have an older Delta single handle shower scald guard. Water pressure from the cold side is fine. When I turn it to hot it slows to a trickle. After a minute or so it picks up slightly but it is then hard...
It sounds like it has mineral deposits in the hot water side. Try taking the internal valve parts completely out of the fixture and examine them. If there is any scaly (light grey) deposits, that would be the problem.
The solution is to soak all the parts in vinegar, which will dissolve the mineral deposits. It takes awhile to dissolve what has taken long to build up, so heat the vinegar, or put it all on a warm, not hot, surface to keep it more active.
I had this problem, and after cleaning it a couple of times with vinegar, I changed out the Delta to another brand. You could also use a water softening unit, which replace calcium and other metals with sodium, thus eliminating the mineral deposit problem.
Jan 25, 2010 | Delta & Single Handle Shower Faucet
Head
Cost about $500 or a little more less for a head depending on what type of engine you have. Labor about $200 - $300 to install. Total for one head $ 900 or a little more again depends on what type of motor.
May 18, 2009 | 1998 Ford Explorer
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
