Question about Oreck XL Professional Air Purifier
How do I access the power cord? - Oreck XL Professional Air Purifier
After removing six screws, how do I get case apart to repair electric cord
How do i replace the power cord on electrolux nimble - Fixya
www.fixya.com/.../t25091002-replace_power_cord_electrolux_nimble
Sep 11, 2014 - Power cord is frayed next to body, need to replace it. how do i get ....See all Electrolux EL8602A Nimble Upright Bagless Vacuum Questions.
Amazon.com: Customer Reviews: Electrolux Nimble Upright ...
www.amazon.com/...EL8602A/.../B004GUFWBM
Amazon.com, Inc.Electrolux Nimble Upright Bagless Vacuum, EL8602A ... The rotating brush on/off buttons are located right under the soft-touch power button high up at .... Cord is a $30replacement part, which I'm regretting not doing from the get-go, due to ...
Apr 13, 2015 | Electrolux EL8602A Nimble Upright Bagless...
Will not operate, no reaction when power button pressed. All panels properly locked.
first off does the light come on at all? when the switch is moved to the High Medium or low setting do you see a red light or a green light on the right side of the unit? if there is no light at all, then there is either no power and you have a bad cord or a bad outlet. The only other thing could be the switch that needs to be tripped in order to let the unit run, that switch is closed by the front cover locking in place. that switch could be bad or your cover may have the tip of the pin that pushes the switch closed broken off or deformed and not pushing down enough to close the switch. try pushing a screwdriver down on the switch and see if it comes on. There's nothing that can shock you if you push on that switch, the power wires are concealed inside a plastic covered area that the switch slides into. If you close the switch and it doesn't come on the check the power cord or the wall socket for power. See if the cord has any unusual looking spots or lumps, stretching, cuts or anything that looks suspicious.
Apr 06, 2015 | Oreck XL Professional Air Purifier
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
Where is fuse for ecoquest freshaire
Mine is on the back, just above the pluggin for the cord .
The fuse may be accessed by unplugging the cord from the back of the unit and gently pulling the fuse holder stright out. 100 & 110 volt models use 1.6 Amp slow blow fuse.
220/240 volt models use 1.0 Amp slow blow fuse. Got this info from my owners manual. I would also check to see if the on/off switch in on, this is just above the fuse. I hope this helped.
Feb 02, 2013 | Ecoquest Fresh Air Air Purifier
Device appears to have no power. Power cord looks good, it was working the day before then suddenly stopped working... no lights indication of any power making it to the device.
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Aug 16, 2011 | Honeywell (18155) Air Purifier
MyFresh Air Air Purifer is not working. About 1 year ago I accidentaly put a staple through the power cord to the purifer and it stopped working. I have had it in storage but would like to start using it...
You can use any standard computer power cord for this purifier. If the damage is closer to the plug side of the cord, you could cut the plug end off and put on a new replacement plug. You should be able to find a replacement cord or plug at a hardware store. Hope this helps you.
Jan 20, 2011 | Ecoquest Fresh Air Air Purifier
No power, the cord was damaged tried to fix the cord but still not working
You need an electronic tester to see if power arived to the machine
Sep 30, 2010 | Ecoquest Fresh Air Air Purifier
My blueair 501 suddenly stopped working. I turned it off to move it to another room, and it will not come back on. Outlet has power. Is there an internal fuse I can replace?
The power cord had burned out right at the point where it connects to the female receptable (the end that connects to the unit). Need replacement cord.
Jun 05, 2009 | Blueair 501 Air Purifier
Power dont come on
Some of the older units did have some trouble with the connection for the power cord. Try to push in the power cord all the way and wiggle it a little bit. If it still doesn't come on the unit needs to be serviced.
The FreshAir has a 3 year factory warranty. Make sure to have the unit registered, or have an invoice showing your purchase date.
You can call EcoQuest support at 1-800-989-2299
Let me know if you have more questions
Dutch
Aug 04, 2008 | Ecoquest Fresh Air Air Purifier
Fresh air won't come on
Check the fuse which is located beneath the cord port
Aug 01, 2008 | Ecoquest Fresh Air Air Purifier
Oreck XL Professional Air Purifier Logo
130 people viewed this question
Top Oreck Air Purifiers Experts
brian kossman
Level 1 Expert
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
