Question about Vacuums
I took my Oreck apart to clean the filters. After cleaning and reassembling the Oreck will not start back up. I put a screw driver into the safety switch in the front of the machine but nothing
ukvacfan
  • 328 Answers
SOURCE: Hello I can not find my manual for my vax vs19
Check out this site;
http://www.vax.co.uk/support/vacuum-cleaner-user-guides
Scroll down to the one that's applicable.
Posted on Mar 06, 2009
  • 3600 Answers
SOURCE: LittleGreen Machine Pro turbo brush put back together
here is the web site with the parts breakdown.
http://www.marbeck.com/carpetcleaner_parts_bissell.html
Posted on Jun 19, 2009
b0sslady2001
  • 357 Answers
SOURCE: It's been awhile since I have used my shampoo
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Posted on Jun 28, 2009
  • 7 Answers
SOURCE: Bissell Powerforce bagless 6594 W filter cleaning and reassembly
the sponge filter goes around the plastic part with tons of vertical slits on it
Posted on Nov 05, 2009
Dysonteam
  • 167 Answers
SOURCE: hi, i took apart filters to clean in my dyson dc25
Hi its Darran at Dyson.
It may be worth taking the filter in the ball out and putting it back making sure it has clicked back into place securely.
If you need advice on this, please visit our website at www.dyson.com and click on the support section.
Alternatively, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 16, 2010
Testimonial: "I went to the dyson website...and figured it out thru pictures. Thank you!"
How do I reassemble electrolux EL855 Unirapido vacuum?
try utube for a video on putting together or try Electroilux website for the manual.
Sep 18, 2016 | Electrolux Vacuums
Our combination steam-vacuum cleaner, Oreck has clogged the vacuum tube up into the handle where the bag less filter is? How to unclog or take apart to clean out?
A " mechanicky " person can use a variety of shop items and tricks to clean that out, such as high air pressure, shop vacuum machines, long poker rods, etc. etc. to clean this out for you.
God bless your efforts.
May 19, 2016 | Oreck Vacuums
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Ironman canister won't turn on. took it apart to look at switch and wires. nothing loose, but checked everything... then it worked. today... no signs of life...?
The switch may be failing. You can check switch continuity and operation while the machine is disassembled but it is likely to wait until you have reassembled the machine to fail again.
Feb 13, 2015 | Oreck Vacuum Ironman Canister Vacuum Bags
No suction
Take apart. Run all hosing through high pressure water or air compressor.
Apr 13, 2014 | Oreck VersaVac Bagless Vacuum / Steam Mop
Took apart removed belt plugged in turned on power motor shaft will not spin
Check the electrical connections to the motor and make sure they didn't come loose. Also most people don't know the motor shaft can become dirty and needs to be clean and shinny. Clean with steel wool.
Nov 22, 2013 | Oreck XL2200 Bagged Upright Vacuum
My Oreck vacuum cleane won't turn on
I have an Oreck vacuum. My son used it just earlier today and it worked just fine, then just a little while ago a tried to turn it on to vacuum our bedroom and suddenly it won't turn on! I tried plugging it into other outlets but it was no use. My husband takes a look at it and first thinks that the switch is out in it. He takes the handle apart and quickly realizes that it is not the switch that is causing the problem. Then he took the base of the vacuum apart, removes the spin brush part and cleans it off, puts it back together, and suddenly it works! He said that when those brushes get real dirty the motor gets clogged, then it just won't turn on. I'm just happy I married someone who can figure these things out, because even if I knew the problem I'm still no good with a screwdriver, taking things apart and putting them back together again. Hope this works for your Oreck too and it's running again for you soon.
Jun 18, 2010 | Oreck XL2200 Bagged Upright Vacuum
Rainbow
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=779655
Rainbow
Posted by Nat51 on Jul 13, 2008
Hi: I took my unit apart to clean it. I was careful to put it back exactly as I took it apart. Now it won't start. I also need a new filter. I rinsed it out but it still stinks.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way is to check your owner’s manual to see the trouble shooting guide of which may help you. It could be a loose wire; or the separator could be on too tight, I am going to give you the Rainbow / RexAir Factory phone # so that you can check with cust serv or their serv tech support. Feel free to contact your local vacuum cleaner dealer in your area also.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 13, 2008 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
