Question about Health & Beauty
Wherecan- I get a used transaxle for a wheelchair?
Renting of a wheelchair in george cape province south africa
Wheelchairs in George, Western Cape ' Yellow Pages South Africa
www.yellowpages.co.za/search/wheelchairs/george,+western+cape/1
Wheelchairs for hire are available in retail shops.These are ... 8 Medical Cntr, 33 Courtenay St, George, George, Western Cape, South Africa Get directions.
George Wheelchairs ' Hire a Wheel-chair George - ShowMe™ South ...
showme.co.za > ... > Health & Fitness > Medical Practitioners, Services & Supplies Manual operated and electric, motorized wheelchairs and all terrain wheelchairs and mobility scooters to hire or buy in George.
George Medical Practitioners - ShowMe™ South Africa
showme.co.za > George > Lifestyle > Health & Fitness Find Medical Practitioners, Services & Supplies on ShowMe™ George.
Wheelchairs / Dis-Chem - Pharmacists who care
https://dischem.co.za/category/353/wheelchairs Items 1 - 12 of 16 - View - Wheelchairs products from Dis-Chem Online, Pharmacists who care 353.
Wheelchair in Western Cape ' Gumtree Classifieds South Africa
https://www.gumtree.co.za/s-western-cape/wheelchair/v1l3100001q0p1 Results 1 - 20 of 155 - Find wheelchair in Western Cape! View Gumtree Free Online ... Published in: Rentals Offered , Plettenberg Bay. Wheelchair for sale - used ...
Solutions Medical - Home
www.wheelchairs.co.za/ Wheelchair, pressure care and assistive devices for rental and or purchase. Renting of wheelchair in george cape province south africa Google Search
Mar 28, 2017 | Computers & Internet
Wheelchair Transaxle Drive
fixya sit does not sell anything
try shops that cater for wheel chairs
Dec 22, 2016 | Retail Supplies
Show me how to repair a cv joint Saturn vue 2006?
Transaxle Removal & Installation
Fig. Disconnect the shift control cable (3) from the range select lever (4)
  • Remove the upper transaxle to engine bolts (1, 3, 5, 6) and stud (2).
    Fig. Remove the upper transaxle to engine bolts (1, 3, 5, 6) and stud (2)
  • Safely support the engine.
  • Remove the transaxle mount to transaxle bolts.
    Fig. Remove the transaxle mount to transaxle bolts
  • Remove the transaxle mount to frame rail bolts.
  • Remove the mount from the engine.
    Fig. Remove the transaxle mount to frame rail bolts
  • Remove the left transaxle mount
  • Raise and safely support the vehicle.
  • Remove the front wheel and tire assemblies.
  • Remove the splash shield.
  • Remove the bolts (2, 3) from the transaxle brace.
  • Remove the transaxle brace (1).
    Fig. Remove the bolts (2, 3) from the transaxle brace
  • Remove the starter.
  • Mark the relationship of the flywheel to the torque converter for reassembly.
  • Use the J 43653, Flywheel Holding Tool, to prevent the crankshaft from rotating.
  • Remove the torque converter to flywheel bolts.
  • Remove the nut holding the transaxle cooler line retainer to the transaxle.
  • Disconnect the transaxle cooler lines from the transaxle.
  • Disconnect the Vehicle Speed Sensor (VSS) wiring harness from the sensor.
  • Remove the steering gear intermediate shaft pinch bolt.
  • Disconnect the tie rods from the steering knuckle.
  • Disconnect the stabilizer shaft links from the stabilizer shaft.
  • Disconnect the ball joints from the steering knuckles.
  • Remove the frame.
  • Disconnect the wheel drive shafts from the transaxle.
  • Support the transaxle with a suitable jack.
  • Remove the lower transaxle to engine bolts (5, 6, 7, 8).
    Fig. Remove the lower transaxle to engine bolts (5, 6, 7, 8)
  • Separate the engine and the transaxle.
  • Remove the transaxle from the vehicle.
  • Flush the transaxle cooler and the lines with J 35944-A, Transaxle Oil Cooler Flusher.
  • Remove the following only if replacing the transaxle.
    1. Remove the shift cable bracket bolt (3), nut (1), and bracket (2).
    2. Remove the PNP switch.
    3. Remove the transaxle mounts.
      Fig. Remove the shift cable bracket bolt (3), nut (1), and bracket (2).
  • To install:
    1. Install the following if previously removed
      1. Install the shift cable bracket (2), bolt (3), and nut (1).
      2. Tighten the bolt (3) and nut (1) to 16 ft. lbs. (22 Nm).
    2. Install the PNP switch.
    3. Install the transaxle mounts.
    4. Position the transaxle in the vehicle.
    5. Install the lower transaxle to engine bolts. Tighten the bolts to 55 ft. lbs. (75 Nm).
    6. Install the wheel drive shafts to the transaxle.
    7. Install the frame.
    8. Lubricate the transaxle cooler pipes before inserting into seals.
    9. Connect the transaxle cooler pipes to the transaxle.
    10. Install the transaxle cooler pipes retainer nut. Tighten the nut to 62 inch lbs. (7 Nm).
    11. Use the J 43653, Flywheel Holding Tool, to prevent the crankshaft from rotating.
    12. Install the torque converter to flywheel bolts. Tighten the torque converter bolts to 44 ft. lbs. (60 Nm).
    13. Install the starter.
    14. Install the frame.
    15. Install the steering gear intermediate shaft pinch bolt.
    16. Connect the ball joints to the steering knuckles.
    17. Connect the stabilizer shaft links to the stabilizer shaft.
    18. Connect the tie rods to the steering knuckle.
    19. Connect the wiring harness to the VSS.
    20. Install the transaxle brace.
    21. Install the transaxle brace bolts. Tighten the bolts to 39 ft. lbs. (53 Nm).
    22. Install the front splash shields.
    23. Install the front wheel and tire assemblies.
    24. Lower the vehicle.
    25. Install the left transaxle mount.
    26. Install the upper transaxle to engine bolts and stud. Tighten all of the bolts and stud to 55 ft. lbs. (75 Nm).
    27. Untie the radiator, air conditioning condenser, and fan module assembly.
    28. Remove the engine support fixture.
    29. Connect the transaxle wiring harness to the main transaxle electrical connector, and the PNP switch.
    30. Install the shift control cable to the shift control cable bracket. Ensure the cable retaining clip is fully seated.
    31. Connect the shift control cable to the range select lever.
    32. Connect the air duct hose to the intake plenum.
    33. Install the battery tray.
    34. Inspect the transaxle fluid level.
      NOTE
      It is recommended that Transmission Adaptive Pressure (TAP) information be reset. Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, the ECM, PCM or TCM will need to relearn TAP values. Transaxle performance may be affected as new TAP values are learned.
    35. Reset the TAP values
    Jul 22, 2014 | 2006 Saturn Vue
    I can't find a code to use with my cable remote for this tv. Wherecan I find the codes?
    Check the remote manufacturer's website. Or if it is from a cable provider, they will have it on their site.
    Feb 28, 2011 | Televison & Video
    Wheelchair accessible problem
    If a building is "wheelchair accessible," it means that it is constructed to allow a person using a wheelchair to move around without being obstructed, and with access to all the features of that building including its bathrooms and multiple levels.
    Sep 14, 2008 | Jet 3 Ultra Power Chair
    Wheelchair support
    First of all, you should be aware of your Center-of-Gravity. Many activities require the wheelchair user to reach, bend and transfer in and out of the wheelchair. These movements will cause a change to normal balance, center-of-gravity, and weight distribution of the wheelchair.
    To determine and establish your particular safety limits, practice bending, reaching and transferring activities in several combinations in the presence of another individual BEFORE attempting active use of the wheelchair. roper positioning is essential for your safety.
    When reaching, leaning, bending sideways or forward, it is important to use the casters as a tool to maintain stability and balance. When you are reaching, leaning and bending forward, position the casters so that they are extended away from the drive wheels and engage wheel locks.
    Never attempt to reach an object if you have to move forward in the seat or pick them up from the floor by reaching between your knees. When you're reaching or bending backward, position wheelchair as close as possible to the desired object.
    Position the casters so the are extended away from the drive wheels to create the longest possible wheelbase.
    Reach back only as far as your arm will extend without changing your sitting position. When another person is tipping the wheelchair, he should grasp the back of the wheelchair on a non-removable part.
    Inform the wheelchair occupant before tipping the wheelchair and remind them to lean back.
    Be sure the occupant's feet and hands are clear of all wheels and/or any other pinch points.
    Sep 14, 2008 | Jet 1HD Power Electric Wheelchair
    Wheelchair Question
    Nowadays, wheelchairs can be cheap to purchase and are widely available, so choosing a wheelchair can be confusing. Somebody using the wheelchair independently will require a self propelling (large wheels) model they push themselves.
    A self propelled, or transit wheelchair (smaller wheels) will be appropriate if the wheelchair will be pushed by an attendant. A folding wheelchair is a good choice for occasional use as they can easily be dismantled, folded and transported by car. It is much easier for the disabled to get around independently than it used to be, and there are two types of wheelchair on the market that come with an engine. Motorized scooters and motorized wheelchairs.
    Motorized scooters can negotiate curbs and road crossings easily and does not need much physical strength making it easier for elderly people to use.
    The motorized / power wheelchairs were designed for people who have very limited mobility, this is powered by a joystick in one hand for easy use. This product is can also negotiate with curbs and road crossings reasonably easily.
    You should choose this type of wheelchairs if you are an independent person who would not like help with it. Realize again that these are less maneuverable than self-propelling chairs. Notice that you will not be able to fit these in most cars although you can fit them in modified vehicles.
    Sep 14, 2008 | Excel 1000 Wheelchair. 16" Seat,...
    Health & Beauty Logo
    73 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
