Question about Konica Minolta Magicolor 8650DN Colour Laser Page Printer
How to fill developer in drum for konica minolta 8650
  • Konica Minolta Master
  • 6,674 Answers
YOU DONT! you replace the units as a whole
Posted on Jan 08, 2017
Konica minolta 185 m2
Clear the counters for drum and developer, Replace the drum and developer, run required process, done, Do not reset without replacing because copier uses the counter if you reset without replace code and image problems will begin. Because copier will think drum and developer are new when in fact there are not and voltages set for new will be working on old stuff.
May 26, 2016 | Konica Minolta Office Equipment & Supplies
Konica minolta 7272 error codes sc50-5 & 29-4 ....... what can I do......... any solution plz
Mam/Sir,
SC 50-5 is that main drive motor can not turn properly, the second code is that you drum sensor is not reading the drum, For both codes you will need a tech that has some legacy Konica experience might need a a new drum when was last time developer was installed? Might need a new motor or worse case a main control board. Both codes require removal of the drum/developer assembly. Sensor for the drum is under the drum and requires drum removal. Will also need a new cleaning blade which might be the reason the drum can not turn. Developer for the developer section. Try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 14, 2016 | Konica Minolta Office Equipment & Supplies
Konica Minolta 7272 coad 29-04 how was the solve
Have the developer and drum replaced. Ensure tech clears the counters first before installing parts, and run required post checks while in the drum cart clean the sensors and remove old toner and developer. Your code is dealing with the drum and developer. Developer is replaced 250,000 copies, drum 250,000.
for parts try this site for starters:
Jun 24, 2015 | Konica Minolta Office Equipment & Supplies
Magicolor 8650 polygon motor
Polygon motor is located inside the print head along with the LASER
Apr 30, 2014 | Konica Minolta Konica-Minolta 4599161...
Konica Minolta Magicolor 8650 C4153 error
replace the yellow print head which houses the LASER for the yellow drum print head is located below the yellow image unit (each color has one). It is a "######" to get out, recommend a tech do this.
Feb 17, 2014 | Konica Minolta magicolor 8650DN All-In-One...
Sc29-08 konica minolta
Magenta drum sensor remove the magenta drum and clean the small sensor the seats behind the drum front of drum small silver looking device with a very very small square opening. use brush or air.
Feb 08, 2014 | Konica Minolta Konica C500 Developer
KONICA MINOLTA BIZHUB163 MAINTENANCE CALL M2
Replace the developer and drum make sure counters are cleared for the drum and developer. because machine works off the counters if the counters are clear it assume new drum and developer are installed and set voltage to the drum and developer based on it, if in fact he drum is not new or developer then image problems and code can appear
try web site below as start to get parts, recommend Konica Minolta tech do it.
Jun 07, 2012 | Minolta EP4000/5000 CS/PRO Copier
Toner fly in Bizhub 500
The problem may be comming from the drum unit, there is a small over sray tray right under the developer mag roller. It is mostly filled up with waste toner or dropped toner from the mag roller. You have to take out the drum unit and then the opc drum and vaccum out the tray and that should take care of the problem for now... The problem will come back..... Have you ever had the developer and or the drum & blade replaced. Minolta are a duel component copier. When the developer is worn out it will start to trow toner and fill up the small tray under the dev. mag roller..... Good Luck
Jan 18, 2009 | Office Equipment & Supplies
Konica Minolta Magicolor 8650DN Colour Laser Page Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
