Question about Garden
Plow does not work in any direction. when I push control I can hear seloniod activate but motor does'nt come on and plow does'nt move.
  • 575 Answers
Did you check the fluid? You will need to test the solenoid and the motor with a volt meter. Usually it's the solenoid. Clicking is not enough to determine it's condition.
Posted on Dec 22, 2016
Plow angles left no matter what button i push.
been there!
low voltage to the pump will not allow activation of the relay that changes direction of fluid flow. The pump takes lots of power, and if supply is low, there isn't enough for the other circuits. Clean "all" the ends of power cables, positive and ground, and coat with di-electric gel, buy it by the tube at auto parts store for $6. Also check the contacts in the cab control and on the relays. there could be a defective relay, which you can check with a hot jumper and ohm meter or load. Feel for good strong click vibration and electric flow thru big contacts when activated. Some relay are grounded thru the mounting bolts, others have a separate wire, 1 or 2 of the small ~ # 10 wires connected to small bolts. If only one then take relay off and clean the mounting surfaces as this is the path for the ground.
Mar 04, 2015 | Cars & Trucks
When i try to lift or angle my plow all i get is a clicking sound when i push the lift button and when i let up on the button the moter on the hydrolic unit will click but will not move the plow. minute...
Not familiar with model, but valves click at the same time motor is suppose to run. Check power and ground to motor (or try running it with jumper cables, but don't be where plow can angle and squish you. If good power but won't spin, clean brushes/commutator/check bearings in motor.
Aug 15, 2014 | Cars & Trucks
Fisher minute mount 2 plow won't move.the motor runs but no plow movement? Is the pump bad?
You may have to bleed air out of the system to get it to work properly. Hope this helps.
Jan 02, 2014 | Cars & Trucks
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
No heat engine warm fan works on all levels directional control (defrost@floor) stuck on cold. ?temp control .
your heater core could be plugged if your anti-freeze color is a brownish colour , most likely your heater core is plugged also when you move the direction for heat control can you hear the blendoor move if you can then again your heater core may be plugged and if it is plugged flushing most likely wont fix it, if you don't hear the blendoor motor move the blendoor motor or the door may be damaged
Dec 09, 2010 | 2002 Ford Taurus
My fisher plow wont move
Sounds like pump is not working, check all fuild lines. Unless the plow is all electric, then the ground
Feb 26, 2010 | 1998 Chevrolet C1500
I just bought a 1986 chevy 1/2 ton with a fisher plow. I hooked up the plow and it won't go up or down, or left or right. The controls work, if I move the pistons on the valve body it still does'nt work....
un bolt the motor from the base, the pickup is just tin, they rot off and fall into the base. you may have valves stuck too, but if nothings moving and pumps running, it should labor BADLY
Sep 04, 2009 | 1985 Chevrolet Chevy
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
