Question about Pool & Spa
Wiring diagram for type TECCM17120 MOTOR - Pool & Spa
Motor needs replacement
Most manufacturers have all that information on their websites. Try visiting Bissell's website and in the search bar, type in "motor wiring diagram".
Apr 20, 2014 | Bissell 4104 Bagless Upright Cyclonic...
Wiring diagram for terminal board on 2hp 240volt water pump waterflow type 90L-2
Wiring diagram should show on side of pump.
Copy following links for help identifying wires and testing start coil vrs run coil on multi-speed motors.
http://waterheatertimer.org/images/Motor-capacitor2-800.jpg
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Oct 05, 2012 | Hardware & Accessories
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I have a dayton 3/4 hp fan motor. I need to change voltage from 230 to 115. Where can I get a wiring diagram showing the wire changes that I need to make. I have done this before but forgot which wires...
There are many different types of motors. you should have a diagram on the inside of the wiring compartment cover. This is a dayton diagram, but I can't be sure it is the same as the motor you have.Notice line terminals remain the same, but that the internal wires change terminals.
Aug 05, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Pentair WhisperFlo Wiring Help
If you just bought this then there will be a diagram on the motor nameplate and/or under the terminal cover where you connect the wires. Generally speaking, there are two wires inside the motor that change positions depending on 115 or 230 v connection. If one of the wires is on a post common to one of the line leads, that usually means you have the motor set for 115V. Is that the voltage you are supplying to the motor? If there is no diagram you can make out on the motor, post what brand motor and the motor model number for a diagram.
Dec 24, 2009 | Pentair Wf 6 1.5hp Whisperflo Inground...
Wiring diagram for 10 hp tecumseh motor.
no worries go to searsparts.com type in your model # and follow the prompts you can then print it out for free ?
Aug 27, 2009 | Garden
1986 Mitsubishi canter wiring diagram
type what wiring diagram you need into google and click images.
Aug 02, 2009 | 1985 Mitsubishi Pickup
Pool & Spa Logo
46 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
