Question about Panasonic Televison & Video
How do you set and save channels on TV Panasonic model cn677r
    New Friend:
  • 77 Answers
Ordinary if you'll make search automatically - it'll save automatically.
Posted on Dec 22, 2016
My Panasonic plasma tv is stuck on one channel. The remote has new batteries but only works for the volume. I tried changing channels on the set itself and now the screen is black
If the screen is still on but is black, try changing the channel on the set itself back to the channel it was originally on. If you can provide me with the model name of the TV (usually somewhere on the back of the TV), I might be able to find out how to re-set up your remote with it.
Dec 13, 2016 | Panasonic Televison & Video
I can't save channels that i find with manual tuning. that's a panasonic quintrix tv
After your done programming, there should be a topic at the top that says "select"= enable that. If you don't the set will not store saved channels.
Aug 14, 2011 | Olevia Televison & Video
My Panasonic dvd recorder appear to no longer be receiving TV channels it was working and then suddenly not. I canstill view TV through my TV so Im doubtful that it is an ariel problem and I have checked...
Sounds like the inbuilt ATSC tuner has failed; if this is analogue only, it may not be worth repairing that. If however it is a digital tuner, it may not be economical nor cheap to replace at component level. It is up to you, if you want to submit this unit to an authorised Panasonic service centre, to get a quote and second opinion about it. At least then you could make a firm decision afterwards.
The DMR-EZ27K was a reasonable model Panasonic DVD recorder, and it's better than their DMR-ES15V.
Nice unit. The cheapest option I can suggest would be if it is an analogue tuner model, simply connect an external digital set top box to the respective inputs on the unit and record the TV that way (assuming the channels are not encrypted with macrovision). It's crude, but it will save you an expensive workshop hassle.
Mar 16, 2011 | Panasonic DMR-EZ27K
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I hv PANASONIC COMMERCIAL TV - MODEL CT 2522 HE. I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME...
I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME CHANNEL.SOME OF THE CHANELS SKIP,I want all channels to be programmed..pls give the solution
Nov 24, 2009 | Panasonic CT25G7 25" TV
Panasonic plasma won't change channel or volume
Also had the same problem with our Panasonic 50" Plasma...could not change the channel or the volume (with the remote control nor with the actual TV controls). Before I called for repair, I UNPLUGGED the TV and then plugged it back after a minute. I was surprised....the TV started working again. (Switching the TV on and off is not sufficient). I could change channels and volume, etc. So this saved me a repair this time. Might be worth trying this solution. Wouldn't hurt one bit, but rather save you a repair fee.
Aug 26, 2009 | Televison & Video
I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Aug 15, 2009 | Panasonic Televison & Video
No audio
just check that the audio or this channel hasnt been set to zero and saved that way go to channel 4and select the volume up on the remote to ensure it is set to on
Jul 30, 2009 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
