Question about Samsung Washing Machines
How do I do a presoak in Samsung vrt pe washer?
There is no soak cycle on my Samsung VRT washer - how to I pre-soak?
  • 3 Answers
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Posted on Jan 18, 2008
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Posted on Apr 22, 2008
SOURCE: filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
Posted on Sep 03, 2009
SOURCE: samsung vrt washer will begin cycle but get so far
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Posted on Jan 23, 2010
  • 4 Answers
SOURCE: Samsung VRT Steam FabriC Softener not dispensing
My fabric softener intermiitently was left with clear water in the tray. The serviceman replaced the tray which did not fix the problem, he then replaced the valve assembly. That fixed the problem for about a year and now I am experiencing the same problem. Being the unit is now out of warranty, I purchased a valve assembly and replaced it but what I found in the process was that the real problem was that after removing the filter screen where the hose connects I found a SECOND mesh filter that was plugged up. I removed it with a needle from the edge so I didnt damage the screen. I think you could also just used a spray bottle with some water and a Q tip to clean. I wasted $50 on a valve assembly, but I did discover this second filter screen that is not mentioned in the user manual. Hope this helps someone because I have not seen this solution posted anywhere.
Posted on Aug 20, 2012
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer spin cycle error
This is a common problem, check to make sure machine is level an not on a lean, also check the machine feet are all wound down so machine sits firm.if all good then it may be worn out suspension rods
Sep 26, 2017 | Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam...
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
