Question about Garden
Briggs 126t02-0521-b1 only runs with hand over intake on carb? Lots of suction .
On. A craftmen 24" snow blower , only 2 years old ,stays running with thumb over intake on carb ?
  • Garden Master
  • 2,290 Answers
Dirty carburetor . If it has a fuel cup on the bottom of carburetor take it off and clean it out real good Take fuel jet out and blow it out. If you don't have a compressor take a real fine wire and insert into the little hole in the jet and clean any dirt out. That is a good place to start cleaning. Quite often that is all you need.Be careful you don't loose any small parts and make sure the float is in place when you put back together. If the gasket is not seated right it will leak as well. If it has been sitting for a while dump the fuel tank and put clean fresh gas in it as well.
Posted on Dec 22, 2016
I have a 5/24 mtd 2 stage sniw runs with a little choke on and augers spinning. But when i hit snow it dies out
if you can only get it to run in choke , then you have some problem that is keeping the proper amount of fuel flowing , id say most likely inside the carb pathways , Ive had great luck cleaning out carbs with some automotive fuel carb/injector cleaner added right to the fuel tank and let it run (even in choke ) after it heats up the cleaning will begin
Nov 22, 2015 | Garden
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
Why does my weedeater start then it just stops running
sounds like the diaphragms in your carb need replacing. and clean your carb at the same time
Jun 05, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Brand new snow blower
A brand new snow blower ?? Who made it, single or two stage, 2 cycle or 4 cycle, Tecumseh or Briggs or China engine ??
Without knowing it's pretty hard to tell you if it's adjustable. Have you tried reading the manual ?? Did you try asking a dealer ??
Most newer machines do not have any adjustability as to fuel mixture. It's strictly an emissions issue. Many are so lean they won't run properly without being full warmed up before taking the choke off and some will still need a little choke to keep from surging. If you look on youtube you can see many cases of it. If you bought it new you can take it back and have them replace the carb and hope it's better. If you have some skills and are willing to buy miniature drill bits (I did) you can take the carb apart and gently drill out the brass main jet to get some more fuel in there. This is also a procedure you can find on youtube.
Feb 04, 2014 | Garden
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
Snow blower engine starts won't stay running
clean the carb
shut gas off remove bottom of the carb
clean with spray carb cleaner
get into all the holes, blow dry put back together
Dec 08, 2013 | Cub Cadet Snow Blowers. 33 in. Two-Stage...
Last year I purchased a Troy Bilt snow blower . I used it one time after using it I drained the gas out of it. Just recently I got it out and was checking it out because they were talking about snow so it...
I am curious why this repair was not covered under the warranty? This snow blower has a 2 year warranty from the manufacture.
Two things for you.
First, there has always been the "what came first, the chicken or the egg" issue over leaving fuel or draining the fuel from you snow blower. Half the experts say drain it, and the other half say leave it in.
Secondly, all of the current Cub Cadet, Craftsman, Troy-Bilt, Yard Machine, and Yardman snow blowers with the Powermore engine need to be treated differently than the old Techumseh or Briggs side-valve that you were used to.
The issue with your Powermore engine is actually today's ethanol fuel. If you leave the ethanol blends in your tank without a fuel stabilizer the alcohol separates from the gas. This alcohol then rises to the top of the tank and gets into the fuel lines. The fuel lines actually will soften. (I've seen the primer bulb actually melt on a few units)
If you drain the tank and run it dry the remaining fuel will "varnish" and/or dry out the carb.
I know a service manager that repairs a lot of these Powermore motors. Instead of replacing the carb, his techs actually take the carb off, soak it overnight in carb cleaner and then reinstall it. This is so common that he keeps a few clean carbs on the shelf and then just switches them out when a customer has a problem.
So how do you keep from getting those high repair bills? First, use fuel stabilizer ALL THE TIME! Mix Sta-Bil, Sea Foam, or Craftsman Fuel Stabilizer according to the directions on the bottle. Secondly, try not to use ethanol blended fuel. Especially try to fill the tank the last time you use it in the spring with non blended fuel. Third, When you put your snowblower away, fill it with stabilized fuel, start the motor and run it until warm. Then "fog" the carb with SeaFoam spray until it loads up and quits running. Put it away for the season. (If you don't know how to fog go to SeaFoam's website and read about doing this with the spray)
It will start next fall.
Feel free to ask me any other questions about your snow blower. Don't forget to rate this answer and you are welcome to leave a comment about it.
Jan 11, 2011 | Garden
Backfires thrue carb
You may have an intake valve staying open or the spark timing may be off from a slipped flywheel and key. Can spray liguid wrench in the intake to coat valve stem . You would have to take off the flywheel hold down nut and pull starter engage ring to see if the groove in the flywheel matches the groove in the crankshaft. Ive had blowers, weed eaters, tillers and all kinds of small engines break a flywheel key for no apparent reason. Sometimes they are just a little loose and wear out or snap.
May 09, 2010 | Briggs & Stratton Intek Snow Horizontal...
Can't keep my snow blower running under load, cleaned carb, but do not know adjustment procedure for a tecumseh 7.5 hp 15 year old snow blower
there should be an ajustment screw on the carb. turn it all the way in don't turn it hard then turn the screw back out 1 1/2 turn to start out with then after runing turn till it runs evenly.
Dec 20, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
