Question about HP Color LaserJet CM1312nfi Laser Color Multifunction Printer - 12 ppm
I need tear down steps for a HP CM1312nfi MFP. I need to get to where I can check the powerSupply.
  • 62 Answers
SOURCE: Printer "off line"
Check the cable that connects the printer with your computer, also check that printer drivers are installed correctly
Posted on Jan 29, 2010
  • 118 Answers
SOURCE: HP Color LaserJet CM1312nfi MFP printer leaves a 2
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are preventing printing
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for this type os trouble shooting
hope this helps and good luck
Posted on Apr 29, 2010
  • 223 Answers
SOURCE: my HP Printer a CM1312nfi mfp printer is printing
It could be one of a few things, one being the yellow toner cartridge, try using a different cartridge after replacing the cartridge run several cleaning modes from the service menu. If the problem is still persistent it could be the fuser assembly is too hot and therefore is scorching the paper or the etb is dirty. to clean the belt, access the secondary service menu, setup/press setup and cancel at the same time/ press set up again and you should see the secondary service menu/ select clean belt/ do this 5 times.
Posted on Jul 14, 2010
  • 4737 Answers
SOURCE: When printing text in color
Clean the Fuser unit and Remove the Wasted Toner from the Drum, that'll definitely fix your problem. To do these, you have to disassemble the Fuser and also the Drum. If you need further help, let me know with more details so that I can give you the instructions on how to do and how to fix it with the easiest possible hints and instructions.
Good luck.
Posted on Oct 11, 2010
  • 3 Answers
SOURCE: I have an HP Color LaserJet CM1312nfi MFP printer.
I have the same printer and you have to set the default paper size in the printer itself to legal.
Posted on Oct 19, 2010
WIl not print correctly
If it is faded, it could be the transfer roller. I've had great success with simply periodically cleaning it, then getting a good printout. See my solution for this already posted: Check out this solution to the HP Color LaserJet CM1312nfi Laser Color...
Otherwise, the other issue I had late last year was that it needed a new intermediate transfer belt (part #RM1-4436-000CN). You can find a good deal on one, and the instructions for replacement are on page 156 in the service manual:
It's not the hardest replacement ever, but needs 2-3 hours depending on skill, and a little patience.
Mar 28, 2014 | HP Color LaserJet CM1312nfi Laser Color...
How to scan to PDF
This question was answered in HP communities, pleas look at the screenshot attached on this page:
Feb 26, 2013 | HP LaserJet CM1312 All-In-One Printer
Do the color calibration.. chk the print quality, if yes.. end.
If no better to submit in service center ifs comes under major issue..
Oct 07, 2011 | HP LaserJet CM1312 All-In-One Printer
Hp cm1312nfi printer problem error ready to download
The error is due to corrupt firmware and you need to reinstall it.
HP CM1312NFI Firmware Download & Instructions
Please visit the above link and Download the firmware.
"The HP Easy Firmware Upgrade utility provides the HP MFP firmware .rfu bundle and a user friendly method to transfer the .rfu file to the MFP all contained in a self-extracting executable for the Windows operating systems"
Please visit the above link and read all the instructions/ details and upgrade the firmware.
  1. Download the flash firmware updater file from to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate MFP in the dialog window. If you assigned a different name to the HP MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the pc during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. The flash firmware update process is complete.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
Jun 09, 2011 | HP LaserJet CM1312 All-In-One Printer
My HP Printer a CM1312nfi mfp printer is printing yellow. only color I replaced the cartridge ,with one recharge
if the printer has not been used for a while the other colours may have dried out..
try using cargtridge clean function on your printer to ensure all cartridge heads are clean.
I hope this was helpful.
Jan 11, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Printer "off line"
Jan 29, 2010 | HP Office Equipment & Supplies
Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Jan 20, 2009 | HP (Q6473A) Print Cartridge for Color...
HP Color LaserJet CM1312nfi Laser Color Multifunction Printer - 12 ppm Logo
20 people viewed this question
Ben Johnson
