Question about Watches
Pin code to watch them all - Watches
When can I find a pin for my watch band?
If you can't find a pin just get a safety pin and cut out with pliers the length of pin Ben slightly and insert, should be fine for a while
Feb 13, 2015 | Watches
Need to shorten metal watch band
here is a solution..
Each removable link on the watch bracelet has an arrow that indicates the direction of the pin to be pushed out .first decide how many will go out than find a tiny nail to be used as " pin pusher"
Simply align the pin that connects the links with the pin on the wood table and with a small hammer/plier hit it to push the pin out...there it comes..and after taking out linls ,connect the remaining link parts together and put the pin back into....
Some people prefers to use a pro type pin remover..it is a cheap tool..just in case pls visit the URL below..on this link there is an article as Watch Band Adjustment Tool Link Pin Remover too..
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://reviewsalert.com/watch-repair-kit-16-pc-deluxe-tool-kit-repair-pin-remover/
Sep 11, 2011 | Watches
How do I remove a link from a casio watch bracelet?
Thanks
Sep 11, 2011 | Casio EF512D1AV Watch
How do you remove links from a casio watch strap S-1183DV on watch WV-59DU ?
You will need to hold the watch firmly in your hand, with the side pointing up. Make sure that you can grip it firmly. If you have trouble holding onto the watch, place it on a stable surface. Make sure that the side is facing toward the ceiling and locate a connecting pin. There will be a connecting pin on each link of the watch band. Select a link, and hold the eyeleteer over the connecting pin for that link. Carefully place the eyeleteer onto the connecting pin. Push gently but firmly until the connecting pin slides partially out the other side. Occasionally, the pin will be difficult to push through the slot. If this is the case, gently tap it though with a standard hammer. Using a pair of pliers, pull on the connecting pin carefully until it slides out. Keep a firm grip on the watch band so that the links do not come apart before you are ready for them to. Separate the Casio watch band. Repeat this process with additional links until the watch band is as small as you would like it to be. Reconnect the band by tapping or pushing a connecting pin into the band where it is disconnected.
Aug 06, 2011 | Casio Watches
I need instructions on removing links from a Fossil Stella watch
you will need some sort of tool for a pin pusher to actually remove the pin from watch . It can be a strong needle of some sorts but I suggest getting an actual pin pusher to prevent from damaging the watch or hurting yourself.
if you look inside the watch band itself you will see on the links an arrow pointing one direction. That is the direction you need to push the pin since the pin head is larger and cannot be pushed the opposite direction .
On the side of the watch links you will see a small circle endented with a pin head. That is the link pin. Place your pin pusher or other similar sized object and with a small or jeweler hammer slowly and lightly hit the pin pusher down until pin comes out of opposite side , you can use tweezers or needle nose pliers to pull pin all the way out
There are some pin removers that screw also or just push down to pop pin .
Once out repeat process until you have removed enough links that watch fits comfortably. Then slide pins with head of pin entering the side where the arrow on back of link is pointing to. Once all the way in gently hammer rest of pin till flush with link .
Oct 17, 2010 | Fossil FS2919 Wrist Watch
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
    The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    I have a Relic ladies watch that I wear all the time and just love. I recently had the pin to brake that holds the watch to the band. The jewelry store repair man had to drill the pin out to replace it...
    mcdevito75 here, That pin is called a spring bar and is used to hold the band to the watch, the pin must be frozen in place on the watch, Best Bet is to try another jewelery shop, in the meantime you can put a drop or 2 of cooking oil on the pin just as it meets the watch this may loosen the remaining portion of pin.
    Aug 07, 2010 | Relic Watches
    My festina watch has lost the pin that attaches the strap to the actual watch
    Most watches use a standard size pin. Try your local watch shop.
    May 11, 2010 | Watches
    Kenneth Cole Reaction band
    Call 7298600 x 272 ask for a free pin for model rk 5033
    Aug 27, 2007 | Kenneth Cole RK5034 REACTION
    Watches Logo
    16 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
