Question about Seca Health & Beauty
Error message on Seca 763 is 1:12 - Seca 763 Electronic Scale
4 Suggested Answers
rickbrashear
  • 176 Answers
SOURCE: what to do if my weighing scale seca 220 appears error 10:12? i have restart the machine, but still the error appear
i repaired one that did not have batteries installed and ran on ac only the problem was in the power supply. it had a couple swollen capacitors they should be flat on top but bad when bulged out
Posted on Jul 08, 2012
SOURCE: 'out 2' error message shows
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Posted on Sep 21, 2012
fb62685
  • 4 Answers
SOURCE: My Terallion electronic kitchen scale shows an out2 error
I had already solved this after a lot of playing and research, put I thought I;d post it on here for others as the answer was different for other scales listed here. What I did was press the 'Button 1' and 'Button 2' together for 5 seconds. This powered it up and then the display showed 'Cal' with a number on the screen. I pressed 'Button 1' again and it said 'Zero' and then displayed the numbers '0000'. Then I added 1kg of weight and it said 'Cal1'. Then I added 3kg of weight. It said 'Cal2'. Then I added 5kg of weight. It said 'Cal3', then 'Pass'. It then returned to normal mode and now started weighing correctly. I calibrated the weights (Flour and Sugar packs) on another set of scales first, but they were only a few grammes wrong so would be close enough anyway. I hope that helps!
Posted on Dec 04, 2012
Err message on Scale. Tried changing the batteries, but no luck!
Enable to capture zero +/- 2%
One or more of the sensors need replacing
Dec 20, 2013 | Seca 354 Digital Baby Scale Pediatric...
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
Error message
check where u put your machine that place should be well equally balance and check some point should the there backside of this for resetting the machine
Sep 20, 2013 | Seca 354 Dual Purpose Baby Scale
Er: 1: 11 appears anytime anyone tries to weigh themselves.
I do not know this particular scale, but you might try this solution that works with many electronic scales. To activate the scale, lightly tap the scale, placing enough weight on the scale to initiate the electronic process. (A foot tap will do.) Wait for the display to show 0000 (or whatever the ready state display of your unit is), and THEN step on the scale.
Mar 03, 2011 | Seca 780 Robust Digital Column Scale /...
How to calibrate seca 354???please help me...
I don't know if the 354 can be calibrated.
Here are calibration instructions for the 374. It includes a toll free number to call seca in case this doesn't work.
http://ons.wvdhhr.org/Portals/20/PDFs/policies/2.12%20Anthropometric%20Measurements%20Attachment%20-%202.pdf
May 19, 2010 | Seca 354 Digital Baby Scale Pediatric...
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Health & Beauty Logo
117 people viewed this question
Top Seca Health & Beauty Experts
pawnpower
Jaye t rock
Tom Chichester
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
