Trying to get my TV can't find manuel or remote
Trying to get my Quasar SP3431W 32" TV to work can't find manuel or remote because of move. Only trying to get a Memorex DVD MVD2047 player hooked up to watch movies. First off a little black square is on the screen, I can't even read the numbers on the screen to see what channel it's on its all fuzzy.
    Novelist:
  • 112 Answers
Press the "Input" or "Source" button on the television while you have the DVD player on. Press it repeadly until you see the DVD picture on the screen.
Basically, just try changing the input on the TV to the input that the DVD player is hooked to.
If this doesn't work, you may have to get the original remote, or get a universal remote to control some of the television's features.
I hope this helps :)
Best Regards,
James
Posted on Jul 21, 2009
How can i unlock tv with no remote
Infra Red LIGHT OUT My original remote control stopped working, so I purchased a universal remote and went through
Nov 27, 2012 | Quasar SP-3235 32" TV
Quasar VV-1301 cant program for cable tv channels without remote, is there a way to autosearch the cable for channels so they are able to be selected
Ur tv have a manual Menu button on the front of the tv bazel frame?Yes used that manually Menu button pushes go into the tv menu to find select CABLE do autosearches by hand through a manually selected by functions buttons like channels buttons up and down as selections and menu button as enter to excicute functions.No try website like Remotes.com to buy the tv original remote to used.
Aug 18, 2011 | Quasar SP-3235 32" TV
Satellite connection to tv doesnt recognize
At least you know the set does work. I'm also assuming your satellite receiver is working and that all your cables are good.
There are two ways to hook up to the TV: RF (antenna) and the A/V jacks. Maybe the seller was using the RF input (the threaded round connector where you screw on a cable connection, then choose channels with the set's tuner), and you're trying to connect using the A/V jacks (the red, white and yellow RCA jacks). If that's the case you need to switch the TV to those inputs. You may need the original remote to do that if the TV doesn't have a front panel TV/AV button.
The other possibility is you're connecting the satellite receiver to the RF connector and the TV isn't on the right channel (usually channel 3 or 4). If you're using the RF input, have the TV autoprogram and it should find the channel. Most sets can do that from the front panel menu button.
Hope this helps. Thanks for sing Fixya!
Feb 19, 2010 | Quasar SP-3235 32" TV
How do I remove the closed captioning box on my tv
There should bea button marked caption. Try pressing that
May 27, 2009 | Quasar SP-3235 32" TV
Please help!
The code for the Sylvania 6432te 32" TV with the "Innovage products- Jumbo universal remote" is 189. you push and hold down the code search button, when the light starts to flash, hit tv, then the number "189". Finally, push the power button off on the remote control. if the tv turns off, then it worked. :)
Nov 05, 2008 | Sylvania 6432TE 32" TV
20 year old Quasar colour TV (no remote)
That is because the switches of the front panel buttons are stuck or defective.
Try first unplugging power for ten minutes, this probably wont work.
To fix this the TV must be taken apart from an expert, and front panel replaced.
You can enquiry here for parts.
What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
Oct 11, 2008 | Quasar SP-2723 27" TV
I need the code for a celera tv
need codes for the URC-3220 remote control
Apr 21, 2008 | Quasar SP-3235 32" TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
