How to hook up 20 pound tank to Mr Heater - Heating & Cooling
5 Suggested Answers
SOURCE: 20 lb tanks
Yes you can use a 20lb tank to run the heater. I purchased a adaptor hose it hand screws into heater & screws onto tank works fine. Bought the adaptor hose at HD.
Custom Contractor
Posted on Jan 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: i have a small dyna glo that takes a propane
There may be dust building up in the ODS safety pilot assembly. The simplest way toresolve this is to flish the pilot with rust buster. Why rustbuster? It has a telescoping tube that makes it easy to direct the squirt into the pilot. Let it dry then retry. You will be amazed.
Posted on Nov 10, 2009
  • 2463 Answers
SOURCE: My Mr Heater Buddy heater 4000 to 9000 btu unit
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
Posted on Jan 30, 2011
  • 5089 Answers
SOURCE: Can I install 4500 wt elements in a marathon MR50238? The tank specs are the same as MR 50245.
1) Product warranty will be voided if you install 4500 watt elements in year-2008 model MR50238 3800 watt marathon tank.
Older 3800 watt element models have been discontinued.
2) Copy following links for Marathon resources:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Product warranty is voided if element wattage exceeds label on side of unit.
4) Marathon has a problem with elements burning out frequently.
To solve this problem, they suggest installing element with lower wattage, such as the 3800 watt.
Upper 3800 SP610130
Lower 3800 SP210197
Posted on Feb 21, 2013
Do I need to have both or one pound bottle to use 12'hose on 20 pound tank? I see some don't use any is there a chance a leak may happen?
you can use either the 1 pound bottles or the 20 pound, The hose that you screw into the Mr Heater, goes onto the connection that a 1 pound bottle would go on. The right side bottle is where I have mine connected, there are no leaks
Feb 12, 2015 | Mr. Heater Big Buddy Heater
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
Jan 30, 2011 | Mr. Heater Mr Heater Portable Buddy...
My Big Buddy heater inconsistently works on high. The low and medium settings work fine (single ceramic element) but when I turn it to high (activating the second element) the element does not fully light...
I did some research on these units-- I pass them on to you-- Do these help?
your Mr. Heater the model that uses two small one pound cylinders or you have the choice to hook it up to a single larger tank? if so, you must use the special filter connected to the Mr. Heater and then your hose to tank.
This happened to me and after I hooked up the filter my problem was fixed.
Ron
large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
just one new cylinder, it will run on just one, to verify a problem with the cylinders. Also it could be the pilot light, sit and watch the pilot light to see if it goes out for some reason. If it does the heater will shutdown automatically, but you already know that.
Let us know if we can help further?
Mack B
Jan 17, 2011 | Mr. Heater (F274825)
It will lite and run for about a minute. If I take the top off it will lite and continue to run. But if i put the top back on it will go off
Here is some research I did on Mr. Heaters--
I hope they help:
Ron
Let us know if we can help you further?
Mack B
Jan 17, 2011 | Reddy Heating & Cooling
My heater stays lit for a few minutes then goes out. Also it has a high pitch whistle when on low.
Ron
Let me know if we can help you further
Mack B
I have a small dyna glo that takes a propane cyclinder. i bought the hose to hook up to a 20 pound propane tank. every time the tank gets below a half tank the pilot light blows out and heater cuts off i...
Nov 10, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Hayward heater not working
You'll never get enough gas from a 20 pound tank. Even 100# tanks struggle to evaporate enough gas to keep up with that heater.
In the mean time, what is the output pressure on your regulator?
Jun 15, 2009 | Hayward H Series Induced Draft Abg 100,000...
Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Jan 19, 2009 | Mr. Heater (F274825)
20 lb tanks
Custom Contractor
Jan 01, 2009 | Dyna-Glo Double Tag-a-long Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
