Question about GPS
I lost the SD card , now my GTV-X1+ always when i run the GPS displaying " storagecard/nwdsoftware.exe ",Ver : F201-F201-6026-100317(window@CE 6.0) Please help, where to find this file
SOURCE: my gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
Posted on Sep 23, 2007
SOURCE: downloading software for Canon imageCLASS MF6550
Posted on Mar 01, 2008
SOURCE: Destinator is not a valid Windows CE application
Download a valid Destinator via torrent or emule and update your sd card
Posted on May 26, 2008
SOURCE: I lost my sd card for my venturer hps9308. Is
Posted on Mar 23, 2009
SOURCE: I have an A2265FF all
Meu GPS n
Posted on Aug 29, 2010
At Startup it displays a message saying "Launcher program is not ready.Please contgact your sales point"
The features are:
* MS Windows CE.NNET 5.0
* 4.3 inch Samsung TFT LCD 65K
* Samsung S3C2400 (400MHz) CPU
* High Sensitive GPS Receiver (SiRF III)
* 64MB SDRAM / 64MB Nand Flash
* Rechargeable Li-Polymer Battery
* Multimedia Player / Image Viewer
* Insert SD Card slot support up to 4GB (SD Card Makers Should Be Tested and recommended CNS Marketing)
* Including SD Card 1GB
alextheboss has attached the following file
Sep 04, 2013 | Computers & Internet
When the computer turns on it says.... " Application explorer.exe encountered a serious error and must shut down. Just purchased the computer and it will no go pass this error message
"Application explorer.exe encountered a serious error and must shut down"means sometime in the past, someone must have installed the OS incorrectly or has deleted something vital, which is why this error is occurring. The only way to bypass this is to reinstall windows OS using the CD that was provided for you, and this error will disappear.
Jun 29, 2011 | Sylvania G-Netbook
Stop play movies screen says no video player installed
ShellDiskShell oPlayer must be corrupted. I have a solution for you but you have to install MioPocket from SD card.
1) Download MioPocket from this link
Extract and copy the following to the root of your SD card:
2) Download a copy ShellDisk from my device here
Extact ShellDisk folder and copy to SD card
3) From SD card, rename Sanyo_AutoRun.inf to AutoRun.inf
4) Create a new folder and name it MySanyo
5) Power on the device, insert the SD card and wait for the install to complete. Now you have a brand new interface with all the tools that Sanyo lacks.
6) To fix the Sanyo video issue, go to Tools menu and open up CE Commander (aka File Manager). Now need to backup your ShellDisk to MySanyo folder.Within CE Commander, open ShellDisk folder on the left side (you should see Log, SanyoNaviConfig, Shell folders and InstallLog.txt). On right right side open MySanyo. Now use a stylus pen and drag and drop one folder at a time from left to right. When prompt, hit Copy. When all folders and files are copied check on the right side and make sure they are there.
7) Let's confirm if Sanyo video player is really corrupted. On the left side go to ShellDiskShell oPlayer and doude-click on voPlayer.exe to open. If same error go to next step.
8) Now, on the left side go to ShellDiskShell folder. On the right side go to ShellDiskShell (this is my copy). First, you need to delete voPlayer folder from left side and drag and drop voPlayer folder from right side to left and hit Copy button.
9) Repeat step 7 and see if you can open it now.
10) Last but not least, recheck if everything is working without MioPocket. Press the red X button on the upper right until you see the power option menu. Select Shutdown and press OK.
11) Eject the SD card and slide the bottom switch to OFF and ON again.
Hope this helps.
Apr 19, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
My navlink gps says "not find navigation software"
If you haven't already fixed this; try going into, settings, navsetup, - this should give a Path of navigation software line, this line should read: '\StorageCard\iGO8\iGO8.exe' click on file icon at end of the path window "select storage card, select iGO8.exe, select tick to apply then exit.
This works for mine but I assume that if an alternative software is shown in the path window you must choose an approppriate .exe file in the storage card files.
Oct 28, 2008 | GPS
Gps Stopped working (Uniden GNS 8431) and this message comes up on the screen- Fatal Application Error mobilenavigator.exe has performed an illegal operation and will be shut down. Program: Mobile...
You hopefully have the mobile navigator software CD that came with the GPS unit. Copy the entire folder and contents of the CD to your SD card (make sure you make a full backup copy of the exisiting software on the SD card first).
John MacLean
Brisbane, Australia
Aug 30, 2008 | Uniden GPS
Plenio GPS 3000
Plenio Is Litttle Picky On What SD-Chip To Use, I Just Upgraded Mine To 2GB SD-Memory
Chip Purchased From Walmart, Mgr Name Is a PNY, Black and Gold Display Case, also
Say's OPTIMA SD Ultra High Speed, Mgr Bar Code# P-SD2GB-FS [On Back Of Display Case]
During My Upgrading to 2GB Chip, Using Plenio-OEM CD," Navigation Map Data Base" DVD-ROM
Version 4.0. Had same problem,
Using Plenio Folder on PC " C:/Plenio/V-Up Pro 3000/VUPro3000.exe, checked box, SYSTEM UPGRADE, Selected SD Memory Drive, [My PC Was F:/], then software should detect SD-Chip
and Display Free memory Size, If So, Then Select Next, Should Take Aprox 20 minutes to Complete
Installing Plenio Software From Your PC to SD Memory Chip.
I'am Sure That IS How It Went For You, Mine Did Not Work For Navigation Either, Everything Else Was OK.
Take Your 1GB Chip And Copy To Your Hard Drive, ie; C:/Plenio/OEM_Plenio_1GB_SD
[Good To Always Have A OEM Backup]
From Windows Explorer Locate This Folder Name On The 1GB SD Chip Directory: MobileNavigator.
In This Folder, Locate File: Device.cfg & MobileNavigator.exe & rdat [No File Extension Displayed]
1] Copy These File's To Same Folder On Your 2GB SD Chip.
Your System Now Has Knowen Operating System Installed and should work like before,
might want to recheck your personal setting's.
I also noted using Plenio Software, I could not Check-Box "OS Upgrade" I think this is why
It Did Not Work. Still have to ask Plenio-Tech About This.
Contact Dan Kim [USA] 408-970-3388 office
I also Noted CD I have Installed Larger Map File Size Than The Preloaded 1GB-Chip Has On it.
located in the "Cities" Folder, file: iusa_110mb_en_standard_cg.cdt 114,232KB
CD Ver 4.01 Installed this File; iusa_180mb_en_cg.cdt 184,145KB
Also Came Up Somewhere With Plenio a: iusa_50mb_en_cg.cdt 48,258KB
I'am Not a Plenio Tech-Rep Just A VXA-3000 Owner
Also Installed 103 MP3's and 20 .bmp Pics/Slideshow, had 480KB Free Memory Left
Aug 02, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Navigon GPS
if your sd card is OK, there should be an update program on it, you have to go to windows ce on the unit to run this program. to do this hold the bottom right key while booting...
Jul 20, 2008 | Fine Digital FineDrive 400 GPS Receiver
gps will not load said destinator.exe "destinator is not a valid windows CE application unit freezes up will not operate , no menu no nothing unit has a sd card could card be blank if so how can I get it reprogramed?...
Oct 27, 2007 | InVion GPS-7v1 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
