Question about Canon IR 2230 COPIER FOR 220 VOLTS ONLY
Canon ir 2230 giving me an error E000024-0001 how to solve this porblem
    Habit-Forming:
    New Friend:
  • 25 Answers
That code means problem with toner sensor in developing assembly, try cleaning it out the best way u can, if that does not help you will probably need to replace toner sensor itself. (Toner Sensor FK2-0358)
Posted on Dec 30, 2016
Cannon ir 2230 giving me an error code E000024-0001 what to do for this?
That means problem with toner sensor in developing assembly. Try cleaning it out, if it does not help try replacing the toner sensor itself.
Dec 22, 2016 | Canon IR 2230 COPIER FOR 220 VOLTS ONLY
How can I solve error e000602-0113?
Problem with HDD.You have to replace hard disk
Oct 11, 2014 | Canon IR 2230 COPIER FOR 220 VOLTS ONLY
E000024-0001 Canon ir 2230
The developing assembly connector may be disconnected.
Re-onnect the connector. If problem not solved replace the toner sensor.If issue not resolved replace your DC controller PCB
Jan 19, 2013 | Canon IMAGERUNNER 2230 Copier
I am using Canon IR 3530 the error code is E000024-0001 please help
I had the same problem on a IR-2230 and I had to replace the Developer Assembly. Check the connection first - have you recently had this worked on?
Mar 07, 2011 | Canon imageRUNNER 2000 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Paper get jaming often.plz give mew solution
Some ir-2230 have an pressure problen on right lower door.
But check the pick up,feed,separation rollers, vertical path rollers,..... clean it, change it,...
Or send more detailed question-Why,when,how....
Oct 28, 2009 | Canon IMAGERUNNER 2230 Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Canon IR 2230 COPIER FOR 220 VOLTS ONLY Logo
105 people viewed this question
old marine
old marine
