Question about Zanussi Ovens
Silk screen inner glass fitting correctly. - Zanussi Ovens
2 Suggested Answers
SOURCE: inner glass on bosch HBC84k550b microwave
Strangely enough I had exactly the same problem but today managed to fit the new inner glass and door panels without any problems, here is how.
YOU NEED 2 PEOPLE FOR THIS STEP. Open the door, at the top are 2 large plastics flat head screws, undo these making sure your helper is holding the door securely or itll fall on the floor, te door will unhook once the screws are fully undone
Once off you can close the microwave back up.
Now there are two screws, one in each top corner holding a funny looking plastic wing shape that slides into the inner door. They have a star screw head. Undo both of these and remove the plastic wings. When you remove these the panel underneath will try to fall off so be prepared to catch it, along with the plastic screws undone in step 1. This now unhooks like the main door did.
From here you'll be able to see the back of the inner glass. This is held in by a mesh at the back and about 15 screws, star headed again. you can simply remove all of these, that will release the front panel over the inner glass, again, you might want someone to hold the door open so the panel does not drop when you remove the last screws.
Thats it as far as taking the microwave apart. put your new glass in, remembering to make sure the rubber seal is put back between the glass and inner door.
Simply reverse the process.
It took me approximately 1 hour and I am by no means a DIY person.
Good Luck
Mike
Posted on Feb 11, 2010
How to fit the internal glass oven door which I have broken and bought a replacement
Here is a general website on how to change a door glass. Just for information, this would be the best I could do with out any information on the model you currently have. Good Luck
Inner Oven Door Glass Panel
Apr 20, 2016 | Ovens
Microwave door glass replacement
yes u can refit it normally.but do it carefully.need more help regarding this let me know .
Jun 16, 2008 | Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
How to I clean the inner glass on a die dietrich pyroclean oven
If you are in the U/K, then go too the following site for a detailed explanation.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR GLASS
You should find a video showing you how to do it
Nov 30, 2010 | Ovens
Inner glass on bosch HBC84k550b microwave shattered following arcing - have ordered replacement but need instructions on fitting it correctly
Good Luck
Mike
Dec 15, 2009 | Bosch Ovens
The inner glass for a Zanussi oven is missing. Is it possible to have this replaced?
Has the inner glass come away from the metal inner door?
If yes, then there are two ways to do this.
The first is to buy a new inner door and fit it to your outer door.
The second is to get a tube of high temperature sealant and repair the existing door.
To repair it you'd have to take the door off the oven and take it apart. Easier than it sounds.
Once the door is off and taken apart, it's a case of take the glass off, clean the glass and the metal, apply the sealant, place the glass on top and then put a weight on it for 24 hours to set.
Then rebuild the door and refit it to the appliance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 04, 2009 | Ovens
Tecnik oven inner glass has fell out. how do i re-fit it
i have never managed to be able to reglue this type of door. you are faced with buying a new part
Sep 30, 2008 | Tecnik TKC8525 Double Oven
Ovens Logo
21 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
