Question about Garden
Need a repair manual for Briggs and Stratton 10A920 type 2073
Specifically for the throttle and governor setup
  • 42 Answers
SOURCE: linkage hook up for a briggs and stratton engine
wow, i have not ran into this problem yet. I am not getting any results for that engine in my usual locations, which have great diagrams. here is a link to the only diagram i can get a hold of. hope this works.
Posted on Mar 19, 2009
  • 661 Answers
SOURCE: 10 HP Briggs and Stratton Throttle assembly
Then print in model no etc. You should get owners manual as well as parts list.
Posted on May 05, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to and view parts for your model.
Posted on May 19, 2009
  • 3 Answers
SOURCE: connecting the throttle assembly to the governor
Posted on May 26, 2010
  • 3740 Answers
SOURCE: need repair manual for briggs
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Posted on May 10, 2011
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Sep 23, 2008 | Garden
One engine startsand you move throttle to run, engine runs at extreme rpm's and will not throttle down
John the governor is probably sticking, check for dirt and debris, make sure spring/ linkages are still attached, after cleaning lubricate linkages with lubricant WD or similar. Check the attached links,instruction and guides, Good luck
Throttle stuck wide open Governor issues
Understanding and Adjusting your Governor on small engine
How To Adjust Mechanical Governor On Small Engines
Briggs and Stratton 8HP Throttle and Governor Setup
Apr 24, 2016 | Garden
How do I time model 128802?
Hallo, I'm looking for a repair manual for 128802-1724-B1 Briggs and Stratton engine. I'm struggling with a the governor setup/ adjustment.
Any help is appriciated,
Jul 21, 2014 | Briggs & Stratton Garden
Governor does not seem to work
Sometimes the governor gear inside the engine breaks and you have to replace it. Did you try to adjust the governor by putting the throttle full and unloosen the screw on the governor arm and push the governor piece the same direction as the throttle opens and tighten the screw.
Mar 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need to reset manual governor on 10 hp briggs and stratton mod # 205412 type 0178-E1. took pan off the governor does not look bad or broke wasker under the governor looks good. I think someone moved the...
First loosen the pinch bolt and nut on the govener arm at the governor shaft. To set the governor make note of the governor arm to open the thottle wide open. Hold the governer arm to where the throttle is wide open then turn the governor shaft that is coming out of the engine block in the same direction until it stops then tighen the pinch bolt and nut on the governor arm to hold the arm in position on the governor shaft. Make sure when you start the engine you don't over rev it. Start it in low speed and move up slowly. You may need to reset the spring tension.
Dec 14, 2009 | Briggs & Stratton Power Products 5,550...
How do you reconnect the two throttle rods on a Briggs 136212 006
Go to this site or type into search
briggs &strattone ngine
Sep 12, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
