Question about Celcus Televison & Video
Celcus 19913 hd I'am getting lines on half the sceen, no picture, but when i plug in DVD on HDMI I'am getting picture on halfe the screen
    Top Expert:
  • Celcus Master
  • 75,462 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 23, 2016
The picture went from full sceen to half a sceen. how do i get it back to full sceen.
need the model number of the set and also is it half the screen left or right or half the screen from bottom to top
Dec 30, 2012 | Televison & Video
I have a Insignia NSL37Q10A, when you turn it on it display's
Change input device to some other like a DVD player. Look for loose contacts in RC jack, cable, sockets. Look for any jammed buttons on TV or on remote.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 03, 2012 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
May 10, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Hp-s5053 samsung plasma with snow on hd content
It appears that the Main bd is bad. Try using Component cables instead of the HDMI cables and see if there is a change. If there is a change to normal picture then try another HDMI cable. If the problem returns then replace the Main bd. There three Main bds for this basic model number. You will need the version# found on the right side of the set to order the correct bd.
Jul 16, 2009 | Samsung HP-S5053 Television
What is broken my hdmi cable,ps3 unit or the hdtv?
I would suggest this (you haven't said what kind of tv you have). I have a 37 in vizio, and a 25 vizio flatscreen HD tv. I had my PS3 hooked up using HDMI first time I tried it I got the little pixels you were talking about...so do this. Sounds stupid but it helped me. The HDMI cable where it plugs into the tv plug and unplug a couple times (three times worked for me. Do the same at the PS3 side of the cable. You want to do this with both of the machines off. Also make sure you have the PS3 configured appropriately for your TV settings...There is a way you can auto setup the screen and sound by shutting the PS3 off and holding your finger on the power button for like 5-10 seconds (it will beep twice) then let your finger off the power button.
When my HDMI cable went bad it would go from having a picture and sound to having no sound and a picture, to no sound and no picture. I thought I had a bad HDMI slot...but it was just a bad HDMI cable
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Dec 21, 2007 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Cutting off the picture
please try once more in the memu on tv
Oct 14, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Televison & Video Logo
Top Celcus Televison & Video Experts
Andrew Taylor
Andrew Taylor
richie46
ray gallant
Are you a Celcus Televison and Video Expert? Answer questions, earn points and help others
