Question about LG Televison & Video
My lg led 32lw 4500 showing only whites vertical lines mix with color on off with remot and sound is ok. Which pcb board required to replace to rectify the fault photo attached
  • LG Master
  • 6,694 Answers
The TCON Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Dec 22, 2016
  • 1554 Answers
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Posted on Feb 18, 2008
SOURCE: 42" LG plasma tv multicolor vertical bars
never buy LG products again !
Posted on Sep 06, 2008
  • 3 Answers
SOURCE: philips 26pf3320/10
there is a get around for this fault if you locate panel v26c look at the bottom rh corner you will find 2 test points tp11 and tp 12 if you then look on the rhs of the lcd panel actualy mounted on the side (you will have to remove the metal frame from around the screen ) you will find another panel with 2 more points tp 506 and tp507 simply solder a wire link between tp11to tp506 and another from tp12 to tp507 and that should be a permanent fix to this problem
Posted on Dec 12, 2009
SOURCE: verical lines on half of the screen
I have the same prob. Please help my *** out here!
Posted on Jun 15, 2010
  • 11361 Answers
SOURCE: LG tv starts up with a grey screen with colored
Grey screen means the T-CON board is not getting the 12vdc feeding it, same for sound. So check to see if you do have 12vdc from the power supply first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Posted on Jul 11, 2010
What part is needed to fix colored vertical lines across entire screen of Samsung tv
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
Can someone point me at the blink codes matrix for this LG line?
Check out the inverter board that powers the back light leds.
Mar 18, 2016 | LG Televison & Video
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    Nov 11, 2012 - Uploaded by LUFERQUINT
Jan 26, 2016 | Televison & Video
Just replace my main board in my lg plasma 50pc3d ud tv all I'm get is sound and vertical line
Recheck all your connections & be sure you have connected all cables properly, looks like you have lost sweep.
If all connections are OK, you may have gotten a defective PCB
Mar 04, 2015 | LG Televison & Video
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
My LG led has had several problems, it started out with the left half of the screen flipping as if viewed from a mirror with the right part of the screen normal. After that, it displayed vertical colored...
This problems are a very tipical of the coded pixels on the LCD screen panel passes through the board that call the T-CON decoder board to causing this problems.Vertical colors lines display on the LCD screen panel happen by itself.Yes.The T-CON decodering board it is dying and shorting out.This T-CON decodering board sit in the middle at the botton of the LCD screen panel.Replacing this T-CON decodering board will solved this problems,if does not the LCD screen panel itself it is shorting out,than the tv it is not worth fixing,because changing the whole LCD screen panel itself it is not practical and the cost will be the same as a new tv itself.Tries websites like, to buy a refurbish T-CON decodering board for the replacement.
May 31, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
Televison & Video Logo
Computer Repairing
Computer Repairing
