I have an Apollo hydro heat system and the hot water tank is cold there is no hot water in house and the heat is blowing cold air, is there a reset button in the tank?
SOURCE: 1992 Jeep Wrangler heater not blowing hot air
How often has the coolant been changed? My only guess is that it hasn't and the hoses and the heater core are plugged up with goo and a flush is needed
Posted on Dec 26, 2008
  • 11 Answers
SOURCE: heater blowing cold air with coolant, fine with plain water
it sounds like the heater core is clogged bad if u know someone with a air compressor put a air nossel on it that you pull the trigger to blos air in to the heater core after you take the lines off i had to do this before on a jeep cherokee it did the job
Posted on Jan 11, 2009
SOURCE: Central heater blows hot and cold air
flame senser
Posted on Feb 23, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
  • 16 Answers
SOURCE: blows cold air on driver side and...
blend motors
Posted on Apr 02, 2010
Hot water heater has hot in tank but dose not come out of hot water line on tank
most electric hot water systems use a heat transfer process where the element is in one tank and the house water is in another
the house water is what is being drawn off when you turn on a tap
there is a regulator valve at the top of the tank with a small lever that you open up to let water in and air out of the system
another point is that there may be a hot/cold mixer on the hot water outlet which limits the temperature of hot water to prevent scalding injuries in the bath and shower or sink
If you have one fitted they are known to malfunction and cut the hot water temperature down as, they mix too much cold water into the hot water pipe.
have a plumber check it out
Jun 13, 2015 | Water Water Heaters
What is causing my car to blow cold air from heat. them it over heats while blowing cold air when hot air does blow car runs fine no overheating please help. 2000 Monte Carlos 3.4
more than likely your losing cold water from your water system, make sure your water pump is up to scratch...sounds strange, but you need cold water for heat through your air conditioning...
Jan 21, 2015 | Cars & Trucks
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
Gas Gauge fluctuates, Overheating even with enough antifreeze & Heater blowing freezing cold air.
GAS GAGE IS EITHER A BAD SENDING UNIT OR "SLOSH MODULE" IF A FORD. HEAT ISSUE IS A VACUUM LOCK IN THE COOLING SYSTEM AND NOT ALLOWING THE AIR TO ESCAPE AND NO WATER TO CIRCULATE.CHECK FOR LEAKS ,THE THERMOSTAT,AND WATER PUMP FOR PROPER CIRCULATION
Oct 09, 2012 | 1997 Mercury Mountaineer
I have an apollo hydro heat system, i need my heat on in order to take a hot shower
RFog, I'd say a 80 gallon hot water tank is much closer to your needs....An easy one.
The rest are difficult.
This I know - the water must be decent and neutral, otherwise, nothing but problems.
Jan 28, 2012 | Home
Heater core is working properly but car will not blow hot air only cold air i am thinking the flapper that controls hot \ cold is stuck in the cold air position
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
Jan 25, 2012 | 2001 Buick LeSabre
1998 ford ranger 3.0. Heat does not work. Replaced thermostat then water pump. Still blowing cold air. Coolant streams out of the top of the coolant tank after engine is at operating temps. Temperature...
Hello did you flush out the cooling system while you had you coolant drained?this would be ideal to do at t hat time.Also be sure to bleed All air out of cooling system to avoid air lock.
Dec 25, 2010 | 1998 Ford Escort
HEAT BLOWS COLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING
You have still got air in the system.Remove the Feed back pipe from the header tank and wait for all the air to come out while the engine is running making sure you are toping up the header tank at the same time Dont allow header tank to run dry while doing this.Good luck
Jan 16, 2010 | 2001 Chrysler LHS
Heater problems
Did you bleed the air oout of the cooling system - Their is a bleeding next to the therostat housing.
1 - When the vehicle is cold remove the rad(tank) cap and top up the level if needed
2 - start the vehicle with the rad cap off and leave the car run until you can see that the therostat has openned(look in tank/rad) to see fuild flow then open the bleeder slowly to let any air out of the cooling system. Once you have coolant flowing out of the bleeder close the bleeder and install the rad/tank cap.
NOTE - Be careful with the engine running and hot Coolant.
You make need to bleeding system 2-3 time to get all the all out. Once all the air is out of the system you problem should be solved. If air returns to the coolant system have the system checked for possible head gasket leaking air into the coolant system
Nov 19, 2008 | 1997 Dodge Intrepid
2000 dodge neon want blow out heat
Did you make sure all the air was bleed from the cooling system? to do this jack the car up in the front with a floor jack as high as poss, then fill the coolant recovery tank up, run the engine until it is hot but not overheated, shut the engine down and let it cool, this should purge the air from the system, if the system checks ok then but later starts to act up again the the problem is a leaking head gasket. One last note make sure the recovery tank is refilled, it will **** down.
Nov 19, 2008 | 2000 Dodge Neon
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
