Question about Refrigerators
The base of the interior of the freezer becomes rock solid with ice so I have now to keep the bottom drawer out as this becomes stuck with the ice . What is wrong and how can I cure it?
    Top Expert:
  • Refrigerators Master
  • 49,159 Answers
Sounds like a drain line is plugged and needs a repairman to clean it for you .
Posted on Dec 22, 2016
Freezer leak, Ice inside the freezer (AMADA ARB220ZC)
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
Jul 08, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
My Hotpoint ffa40x fridge freezerhas a problem,the freezer gets a build up of ice inside the freezer under the bottom drawer which makes the drawer stuck fast until i cut through the ice to release it.This...
your auto defrost heater is not working or you need to defrost it yourself ... turn unit off for a day with doors open. ***********PUT YOUR FOOD IN SOME ONES ELSES FRIDGE ************
Dec 30, 2009 | Hotpoint Refrigerators
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Jul 15, 2009 | Refrigerators
Freezer has 1/4" ice on bottom, everyhing in freezer solid rock.
Your freezer should have a drain located in the bottom rear, usually behind an access panel that allows water to drain into the pan under the unit during the defrost cycle. If this drain becomes plugged, the defrost water has no place else to go but into the bottom of the freezer and turn into a block of ice. Clear the ice and poor hot water down the drain. You may also want to fish something (I use 1/4" water line) down the drain until the end gets to the pan underneath just in case there was something more solid stuck in the drain.
Mar 21, 2009 | Refrigerators
My refrigerator freezes my food solid
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Dec 10, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Freezer is over-freezing
the possible cause is the temperature sensor or thermostat is not working, maybe its switch is stuck up on ON position, it looks like a wire attached to the area where ice is building up, it is connected to a switch to turn off the compressor thus controlling the operation of your freezer. replace with new thermostat will solve the prob.
Aug 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
