Question about Sony Audio Players & Recorders
I have sony cd radio cassette model number cfd-s07cp it power on for 5 second then power off
  • Anonymous Dec 22, 2016
    Help me plzzz
  • 667 Answers
Sony is junk
Posted on Dec 23, 2016
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
SOURCE: CD player says "no disk" when there is disk in player.
My CFD-f10 showed "no disk" after not being used for a few months. Before that it began to stick or skip toward the end of the disk. The trouble was the drive mechanism was failing to move easily due to poor lubrication of the CD drive mechanism. It can be lubricated, but the job is difficult. The top must be opened. First unplug from 120 V and also remove all 6 D batteries, then take 7 screws out from the top. One is under the Tape lid. Two are under the CD lid. Four are along the back. Also take out the screw from the bottom that holds the antenna. There are little arrows next to those screws. Do not take out any more screws than those. Gently lift the top, which includes the CD and tape lids, from the rear while moving the top a little toward the rear. It will seem very tight at first. Do not force it, but keep gently prying. There are circuit boards close to the seam, so do not pry open with long tools. The rear will lift up about 1.5". The handle stays attached to the bottom. Then the flat ribbon cable must be pulled from the ivory socket. The ends of the cable stick into the socket. The socket remains on the circuit board. As the top is raised further, unplug the cables preventing movement, Carefully note where they are plugged in. After the top is opened about 90 degrees, leaving the tape drive still close to the bottom cabinet, remove the 4 CD drive attachment screws with metal washers at the colored rubber washers and also the cable. Now the CD drive can be removed. With very fine synthetic clock oil, I lubricated the end of the motor shaft, (lift the plastic cover a little by unclipping the little snaps.) Very gently operate the mechanism by pushing on the larger gears. Sony had lubricated most, but the lub must have gotten thick with age. Put a little synthetic oil wherever there are moving parts. By turning the gears by hand, you will tell if all is working freely. Then carefully put all back together. Yes the CFD-f10 now does play CDs again!!! I do not know for how long. (Sony style outlet online is selling the newer refurbished CFD-S350 silver boom boxes for about $37.00, which also uses the more desirable 6 "D" batteries, and comes with remote. I have one on order.) The synthetic clock oil can be obtained from any company selling jewery or clock parts, but it is quite expensive, easily half what the refurbished CFD-S350 costs.
Posted on Jan 16, 2010
  • 313 Answers
SOURCE: Sony CFD G505 CD Radio Cassette-Corder - I have no
If it is only 6 months old I would recommend you take it back to where you bought it as it is still under warrenty. If you start playing with it and take it apart the warrenty will be void. But dont tell them about the old trailer house bit, just it stopped working.
Posted on Jul 25, 2010
  • 56 Answers
SOURCE: I have a Sony CFD 5250 Radio Cassette-Corder. Can
The answer is yes, but the ease of doing so will vary. If the unit has an auxiliary input all you will need is a 3.5 millimeter to stereo RCA plug adapter. If it does not have an aux in then it gets more complicated, but it can be done. Do a little digging on the internet for an old cassette adapter. These were used in years gone by to allow the playing of a portable CD player through a cassette deck. The adapter looks just like a cassette, but it has a wire coming off of it with a 3.5 millimeter plug on the end. It will allow you play the I-Pod through the cassette deck just like a portable CD player.
Posted on Dec 01, 2010
dunnbiker
  • 8546 Answers
SOURCE: I can't set the radio
Manual etc here
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDS250
Posted on Jan 15, 2011
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
Power Chord missing
Glen,
These types of radios typically use a very similar power cord. Your local electronics store will carry it. IF you want to order online, try MCM Electronics.
Mar 19, 2009 | Sony Boom Box With CD Player & Cassette...
Power cord?
Hi
you an buy the item in electrical or electronics store
Thanks!
Mar 10, 2009 | Sony CFD-S250 Radio/Cassette/CD Boombox
Mar 31, 2008 | Sony CFD-S200 Cassette/CD Boombox
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
