Question about Hunter Dryers
I cant get the screw back in that attatches the motor to the pole of hunter model 90434
2 Suggested Answers
issken
  • 1472 Answers
SOURCE: I have a model 22272 hunter fan and the lower
chandlermcma
The link below will show you how to reattach your lighs to the main fan.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/42008.pdf
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 01, 2011
I have a hunter fan model 90434 i took the screw that attatches the motor to the pole now i cant get the screw back in
keep trying is all I can suggest . getting them lined up might help . I use an old ice pick myself
Dec 22, 2016 | Hunter Dryers
Cant figure out where the screws hooks go to attatch this to the bench
Could you please describe the problem you are having a little better?
What part? What is the model number?
Oct 31, 2012 | Washing Machines
Have a hunter 52" insignia
Diane, usually, that's an indication that one or more of the fan blade irons are loose, where they attach to the fan's motor. Unfortunately, you're going to need a tall ladder and a Phillips Head Screw Driver to reach and tighten the screws. You'll have to check each fan blade iron one at a time, to find the one(s) that are loose.
Good luck. I hope this helps you solve the problem.
Jul 09, 2011 | Hunter Heating & Cooling
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
My impeller came detatched from the motor
take the back cover off the motor and use a wrench as a back up. it is located at the tip end of the shaft that goes straight through the motor. Hold it tight and screw on the impeller.
Jul 11, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
How do u un bolt from pole
Apparently, although the two halves are screwed together, the unit is riveted to the pole. Those rivets appear to hold the housing together. On mine, it stopped rotating and I think the commutater brushes are bad. I may drill out the rivets, repair the motor and bolt the unit back to the pole (in place of the rivets). horny385, you are a **** and not clever or helpful.
May 25, 2010 | Remington 111409 - 01 6" Branch Wizard...
Need a replacement capacitor
Voltage rating doesn't matter. 250v or 330v will work.
If this is really a 2 speed original, with the 2.5Amp motor... it will NOT have a capacitor as the motor is a shaded pole unit. The three speed electrically reversible fans, have a capacitor, which can either be in the switch housing/ oil reservoir, or the top of the motor housing, depending on year of manufacture.
Oct 24, 2009 | Hunter 23852 Classic Original Ceiling Fan
Cant remove the stand from a Vivo 32"LCD(vslh32e7b) can anyone help??
remove the 6 screws on the back of the tv, the base will then slide out with a plate attatched to it which was origionally attatched to the 6 screws.
Jun 16, 2009 | Televison & Video
Pool motor wiring
I assume you mean a gfci recepticle? If this is the case you need to take the black wire from the house and pigtail it to go to both the recepticle (Black / Line) and one line side screw of the switch. The white wire from the house goes directly to the line/white side of the recepticle. Also pigtail the ground to go to the green screw on the recepticle, the green screw on the switch, the green wire from the motor, and the ground screw on whatever box you're using. When you purchase the switch make sure you get a two pole switch rated for at least the amperage of the motor. The red wire from the house and the black wire from the pigtailed black will go to the two line side screws of that switch. The red and black from the motor will go to the two screws on the load side of that switch. Make sure to ground everything properly being so close to water. The cover needs to be sealed securely and I recommend the cover that has the lever to activate the switch as opposed to the little door over the switch handle. Also make sure the two breakers supplying those two circuits have a handle that turns them both off at the same time.
Sep 01, 2008 | Energizer Rechargable Battery with Charger
Dryers Logo
24 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
