Question about Hunter Dryers
I have a hunter fan model 90434 i took the screw that attatches the motor to the pole now i cant get the screw back in
    Top Expert:
  • Hunter Master
  • 46,416 Answers
Keep trying is all I can suggest . getting them lined up might help . I use an old ice pick myself
Posted on Dec 22, 2016
Where can I get a new motor for my Hunter Designer's Choice Ceiling Fan (model # 99048
Call Hunter at 1-901-745-9222. I think this number is still current, it might not be. Tell them your issue, most likely they will send you an entire new unit (or is your fan the OLD Designer's Choice from the 80's with a rubber flywheel?)
Apr 06, 2012 | Hunter Designer's Choice 5-Switchblades Lg...
Have a hunter 52" insignia
Diane, usually, that's an indication that one or more of the fan blade irons are loose, where they attach to the fan's motor. Unfortunately, you're going to need a tall ladder and a Phillips Head Screw Driver to reach and tighten the screws. You'll have to check each fan blade iron one at a time, to find the one(s) that are loose.
Good luck. I hope this helps you solve the problem.
Jul 09, 2011 | Hunter Heating & Cooling
It is brand new model type 2A Palatine and on high does not spin as fast as other hunter fans we have in our home
I know this is not a fix but in reading alot of posts on the net, apparently the new model fans have weaker motors in them. I have run into the same problem with a new fan that we bought this week. This one is 62" and it does not cool near as good as the one that we took down, which was a 52". I am researching if we can change out the motor to a faster amp motor. Good Luck.
Jun 26, 2011 | Hunter (25417) Ceiling Fan
I bought two Beacon Hill Hunter ceiling fans recently. I bought them because of the promise of "whisper quiet." To my great disappointment the motors are loud. I have one on in another room...
It may not be the motors making the noise, but the blade irons that are attached to the motor are loose and are rubbing the housing.
To confirm this, turn the fans OFF. When the blades stop turning, use a step ladder to reach the fan blades and the blade irons. Using a Phillips head screw driver, attempt to tighten each blade iron screw (2 in each iron), that screws into the fan motor spindle. I suspect, you'll find one or more loose. Especially if, the lock washer wasn't installed on each screw.
Hope this helps you solve the problem. If it doesn't, contact Hunter per the instructions in your Owners Manual. As there is a slim chance that there is a manufacturer's defect involved.
May 06, 2011 | Hunter Heating & Cooling
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
3 speed switch only works on full speed.
Make and model number of the fan is a good start. Ceiling fan or desk or pole or?????
Jul 28, 2010 | Hunter Ceiling Fan Control Switch
Need a replacement capacitor
Voltage rating doesn't matter. 250v or 330v will work.
If this is really a 2 speed original, with the 2.5Amp motor... it will NOT have a capacitor as the motor is a shaded pole unit. The three speed electrically reversible fans, have a capacitor, which can either be in the switch housing/ oil reservoir, or the top of the motor housing, depending on year of manufacture.
Oct 24, 2009 | Hunter 23852 Classic Original Ceiling Fan
Cant remove the stand from a Vivo 32"LCD(vslh32e7b) can anyone help??
remove the 6 screws on the back of the tv, the base will then slide out with a plate attatched to it which was origionally attatched to the 6 screws.
Jun 16, 2009 | Televison & Video
Hunter Fan model no.22570
take it back, and explain to them it will not work. you should be able to get a new one !!
Aug 16, 2008 | Hunter Ceiling Fan Light Switch Control
Chemical smell coming from fan?
I have installed hundreds of fans in homes and businesses. The only smell complaint I have encountered was from a fan that came with rubber band like gaskets around the light shades. I guess these were intended to cushion the glass where the mounting screws contacted it. When the lights heated up the glass, a hot rubber smell became very strong. We tried smaller bulbs with no help. The solution was to throw away the rubber bands and attach the glass with the screws directly like all the other brands. Since then, I have always thrown the rubber gaskets away if they come in the kit.
Jun 18, 2008 | Hunter 21617 Palermo Brushed Nickel...
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
