Question about Pool & Spa
Balboa 500zfilled &overflowedtub switches on pr mode jetsactivateblower on for little while screenflashes sl and temp red light heat onafter an hr tubstops flowing sl stays onbuttons dont work
Balboa filter circulation will not shut off. Temp OK. Not in continious mode.Contacts not stuck.
What model of balboa control do you have?
Will it come right back on after power down / power up?
Does it have a mechanical time clock?
Is temperature of water Hot?
when temp control is scaled down, will it turn off?
what do you mean - Temp ok?
If a mechanical time clock, pull the wires off of terminal 3 & 4,
isolate them! They will be HOT.
1 & 2 are for the timers internal 24 Hr. Motor.
but... First turn power off!
Turn power back on, if pump stays off, bad timer.
Apr 19, 2015 | Pool & Spa
Recirculation pump not starting
check for blown fuse or loose wire on back of pump
Jan 18, 2014 | Pool & Spa
The instrumentation panel says "SL" and the spa isn't heating.How do I get it to heat again?
You have it in "Sleep" mode. Spa will not heat normally in this mode...
If the SL Message is Alternating with the Water Temp in the Display Screen (we call this "Flashing Sleep"), the Spa is Operating in the Sleep Heating Mode.
If the SL Message is ON Solid (Not Flashing) in the Display window of the panel, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
SL or SLP is one of the Modes you can program your spa into:
EC - Economy
ST/Std - Standard
SL/SLP - Sleep
It is advised you keep your spa in Standard mode. Push the Jets button then immediately push the light button. Each press of the light button will scroll between these three modes.
Good Luck
Aug 27, 2013 | Balboa Instruments Duplex Digital Panel 2...
My balboa spa says sl and isn't heating up
SLP or SL Message
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
May 19, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
Had a new heater element installed. won't go
You need to put the system into 'ST' mode. 'SL' stands for 'Sleep' and will prevent your spa from heating.
Feb 24, 2010 | Sys BALBOA SUV SYS 5.5kW W/ 120V 1.OHP...
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Pool & Spa Logo
55 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
