Question about Acer Computers & Internet
Changed boot type from legacy to UEFI. Nowi cant even access bios and machine stops at acer screen. really need to enter back in bios and change back the boot type to legacy bios. Please need ur help
  • Anonymous Dec 22, 2016
    I NOW RECEIVE A BLACK SCREEN OF *****
    Top Expert:
  • Acer Master
  • 24,341 Answers
Changing the boot type will have no effect on whether or not you can still enter the bios.
The easiest way I find is to remove the hdd and RAM. Start up the laptop and it will do odd things. Power it off, replace the RAM with no hdd and go to the bios settings. Once there, reinstall the hdd and go to bios settings, reset back to legacy. Some systems will not support UEFI but if they do, a hdd without a system on a separate partition, will no longer work.
Posted on Dec 22, 2016
acdr
  • 1913 Answers
SOURCE: Toshiba sat. laptop- changed bios password/ cant remember it
u have to open back side of lap top then u see cmos cell out away your cmos batery cell fore 15 minutes then reattch it.then give power up. then iot reset .
Posted on Nov 18, 2008
benwabnick
  • 2404 Answers
SOURCE: acer aspire 4520 bios lock cant format cause cannot boot from cdr
If you don't know the password to get into the BIOS then you will need to call Acer support but you will have to prove to them that your the owner of the laptop. There is no other way
Posted on Feb 08, 2009
coolfixya
  • 82 Answers
SOURCE: Acer Travelmate 4060 boots to bios screen everytime
It seems that your RAMs are faulty..replace it..
Posted on Feb 28, 2009
  • 90 Answers
SOURCE: I want to crack the BIOS password. My machine is not booting and the blue screen comes always.
Open ur system and u can see a CMOS Batterry inside. If you are not an expert just take out the batterry and keep the pc on and off. Put the cell after 1 day and switch on.
Posted on Apr 24, 2009
darkdragons
  • 835 Answers
SOURCE: ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
Posted on May 23, 2009
Can legacy bios ever boot gpt efi, say with a linux efi emulation.
Ok so when it's trying to boot in legacy mode it will see the hard disk as unformatted. Therefore it won't boot Windows 8 or 10. You need to get the bios back into booting uefi.
Resetting the bios should do that anyway, but there is no reason why you shouldn't be able to get into the bios to make that change. Try doing this with the hard disk unplugged so you don't risk trashing it.
Jul 27, 2016 | Legacy Computers & Internet
Samsung 350v5c blue screen, no signal & won't boot
I would recommend resetting your BIOS back to the defaults.
  1. Turn your computer on and use F2 to access the BIOS.
  2. Using the arrow keys, navigate to the Exit menu.
  3. Look for the option (or similar) Load Defaults and press Enter.
  4. Press F10 to save and exit the BIOS.
  5. Your laptop should revert to the default BIOS and boot order settings.
Jul 08, 2015 | Samsung Np350v5c 15.6-Inch Laptop Silver...
How do I install windows 7 after a fatal crash?
Hi Charles,
You will need to access your systems bios. But in order to do so you will first need to disconnect the drive.
Then when you restart, you should see an option to enter the bios (usually F2 for ACERs)
Within the settings, you will be looking for storage configuration or perhaps boot device options. When you find "UEFI" option, change it to "legacy". Then, while you're there, be sure to change your first boot device to CD/DVD ROM. (Assuming that is the install disc you are using). Save settings and reboot.
Should be good to go with a typical Win7 install upon boot but drop a note if not.
Jan 20, 2015 | Acer Aspire Computers & Internet
I have a hp altec 255 laptop .when I put in reinstall disk .windows 7 .computer will not set it up to take program .enyway to get a new hp recovery and applications/drivers reboot disk
please check bios boot type I sujspect it may be booting for UEFI rather than for legacy boot. Windows 8 will boot on UEFI boot type but windows 7 will need legacy bios type of boot up settings in bios
see
http://blogs.technet.com/b/askcore/archive/2011/05/31/installing-windows-7-on-uefi-based-computer.aspx
Dec 21, 2014 | HP Computers & Internet
How to enter bios asus on my asus v550c
On systems with Windows 8 pre-installed, you can access the UEFI (BIOS) setup screens from the Windows 8 boot menu:
  1. Press the Windows key + C, or swipe in from the right edge of the screen to open your Charms.
  2. Click Settings.
  3. Click Change PC Settings.
  4. In PC Settings, select General.
  5. Under Advanced startup, click Restart now. The system will restart and show the Windows 8 boot menu.
  6. In the boot menu, select Troubleshoot.
  7. In the Troubleshoot menu, select Advanced options.
  8. In the Advanced options menu, select UEFI Firmware Settings.
  9. Click Restart to restart the system and enter UEFI (BIOS).
How to access BIOS on an ASUS laptop
Dec 06, 2013 | Computers & Internet
I'm having problems installing Ubuntu on Windows 8.
you have to change the settings in bios setup. normally press f2 or f10
Dec 21, 2017 | Dell Latitude D531 Laptop Computer PC...
Disable onboard video card on dx4870 ub318
enter your Bios then Advanced settings there should be an option to turn of onboard graphics or switch to pci..
Dec 27, 2012 | Gateway Computers & Internet
Pxe-E63 : error while initializing the NIC
Check the boot sequence. For a normal boot, it should be set to hard disk as first item, not the network.
Jul 01, 2012 | Acer Computers & Internet
Tecra A11 can't see all of 3TB drive
Support for Disk Drives Beyond 2.2 TeraBytes (TB) and 4K Advanced Format Sectors
Most legacy systems built before 2011 have a traditional PC BIOS. This type of BIOS uses a Master Boot Record (MBR). The MBR Partitions can define a disk drive capacity up to 2.2TB. Windows operating systems that boot from an MBR are therefore limited to 2.2TB per MBR. A 3TB disk drive in a legacy BIOS and Window system will need a DiscWizard device driver to access the full capacity of a 3TB disk drive. Two partitions will be necessary because of the MBR limitation. The device driver mounts the capacity above 2.2TB with another MBR which looks to the system as a second virtual "physical" device.
GUID Partition Tables (GPT) can define drives larger than 2.2TB. You can use GPT today on any Windows 10/ 8.1/8/7 and Vista system as a non-booting data drive. Windows can only boot a GPT partition on a new type of BIOS called UEFI.
UEFI BIOS desktop systems are new since 2011. Windows 10/8/8.1/7 64-bit and Vista 64-bit operating systems support booting from UEFI and GPT without the need of a non-Microsoft device driver. This is the Windows native solution for booting a 3TB drive to a single partition.
Quick facts about Windows and 3TB drives:
  • Windows 10/8/8.1/7 and Vista support GPT 3TB single partitions
  • Windows 10/8/8.1/7 and Vista can only boot GPT on systems with UEFI BIOS
  • Windows 10/8/8.1/7 and Vista can mount a GPT non-booting data drive
  • Intel RST device drivers before v10.1 do not support 3TB disk drives
  • Windows systems with Legacy BIOS and MBR boot drives are limited to 2.2TB partitions
  • Windows XP does not support GPT
  • Windows XP sees a 3TB drive as 800GB on boot or data drives
  • DiscWizard software can install a device driver which opens the full capacity of a 3TB. You can use it to create a second partition for the capacity above 2.2TB
Sep 27, 2017 | Toshiba Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
