Question about Sony Audio Players & Recorders
What is a resistance reading on sony de 698 display
2 Suggested Answers
  • 159 Answers
SOURCE: how do you connect sony str-de 698 fm receiver to
Connect it's two audio plugs, likely to be coloured red and white, to corresponding sockets on any device that has them and select that input on the device. You should then hear your tuner.
Depending on FM signal strength where you live you may need an aerial, some is always better than none.
Posted on Sep 21, 2011
Resistance does not increase
please read the instruction and fix it. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.Test with the magnet from a refrigerator, If the magnet attract and repulse, is o.k If not replace the magnet.1_21_2013_5_29_53_pm.gif
Jan 20, 2013 | Schwinn 420 Elliptical Trainer
I have no user guide for MFS35PNFTS and machine came up with error 11 fill problem and then I hit the big red button to see what that does and now have no display. How do I de activate the emergency...
Hello I will be happy to assist you please follow the next steps:
    • 1
      Push the "Pause/Cancel" pad two times.
    • 2
      Remove the washer's plug from the electrical outlet. Leave it unplugged for at least a minute.
      • 3
        Plug the washer back in.
      • 4
        Push the button for the desired cycle.
      • 5
        Push "Start."
    If the problem is not solve please let me know or If the display still shows "F11," call Whirlpool customer service at 866-698-2358.
    If this information was helpful please rate my service, this will help me to help others.Thank you very much
    Mar 13, 2012 | Washing Machines
    How do you connect sony str-de 698 fm receiver to television, cable box and cd player
    Sep 21, 2011 | Sony STR-DE698 Receiver
    When i turn the volume up from my sony receiver strda3400es de protection comes in. By lower volumes it works ok.
    Hello
    Measure load resistance. That is the output connected resistance. If it is too low than normal this type of protection will be activated. Measure the impedence [resistance] of speakers connected to the output. It must be more than 4 ohms/channel effectively. OK.
    May 17, 2011 | Sony STR-DA3400ES Receiver
    MLi-698 speaker: what voltage/wattage for the power supply?
    Whatever is the voltage or MLi 698 Hi-Fi Sound Monitor ?
    Mar 07, 2011 | MidiLand MLi 698 Computer Speakers
    Como programar un control de dish a una tele panasonic
    Depende del modelo del control remoto. Pero en general:
    Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
    Use the number pad buttons to enter the three-digit number corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works, try several functions for that equipment.
    Panasonic TV: 508, 509, 510, 511, 512, 566, 574, 575, 628, 644, 651, 662, 663, 668, 672, 673, 676, 685, 687, 689, 698, 697, 700, 706, 714, 716, 234, 247
    Panasonic: 008, 009, 010, 011, 012, 066, 074, 075
    Mar 05, 2011 | DISH Network IR Remote Control
    A rede de meu sony ericsson c510a esta bloqueada ,e preciso do nck pra ativa-la podem me ajudar por favor, nao faço e nem recebo chamadas no display informa chip inativo
    Voc? pode obter o c?digo de descongelar, o c?digo NCK SPCK e c?digo de terceiros. Ap?s o descongelamento de seu telefone, voc? tem que digitar o c?digo NCK para desbloquear e utiliz?-lo com qualquer rede GSM do mundo. Vou sugerir o site de Unlock-Zone.com, que est? fazendo um bom servi?o ..... voc? pode abordar este site Listen Read phonetically
    Nov 23, 2010 | Cell Phones
    My sony str de 835 display went out. sometimes
    Most likly bad solder connections on the display board. Look for solder rings on the LCD. You must remove the front panel to gain access.
    Mar 22, 2010 | Audio Players & Recorders
    Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
    The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
    Apr 18, 2009 | LG WM2487H Front Load Washer
    Sony SDM-HS73P, Ekaitz.
    Hola Ekaitz,
    La tarjeta publicada es un inverter board para el modelo de 19 pulgadas.
    Ante de comprar asegurate que la placa sea la que monta en tu modelo.
    El G mount indicado del otro experto es otra parte, un inverter no cuesta mas de quarenta o cinquenta euros, y por un Sony como el tuyo deveria de ser como veinte o treinta.
    Tienes dos manera de encuentrar el replacement.
    O tomas los numeros impresos en la placa, o llamas por telefono el vendedor.
    Puedes contactar Shopjimmi en ingles.
    Lo mejor es contactar Sony Sony Direct Accessories & Parts Center deberian de hablar Castellano.
    Perdona por las faltas, no tuve tempo para ir a la Academia para mejorar my Espanol, y en el teclado ingles me faltan letras(n) y acentos.
    Dec 29, 2008 | Sony SDM-HS73P 17" LCD Monitor
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
