Clock is flashing, but it will not stop and can't set the clock or the radio. what to do?
  • kakima Dec 22, 2016
    Hi Ronald J Murphy, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model>
How do I set the time
To set the time on a Memorex Mi4604PBLK Clock Radio, hold down the 'set time' button first and then the 'source' button, at the same time. But you must push the buttons in that order, 'set time' and then 'source'. The time display on the front will flash between dim and bright. Use the volume dial to change the time. Time is set, and the flashing display will stop after a few seconds.
Feb 09, 2016 | Memorex MI4604PBLK Ipod/iphone mini alarm...
How to set the clock on a 2008 chevy cobalt
Setting the Clock (H-clock symbol, O-pwr symbol, f-music note symbol)
Without Date Display
AM/FM Base Radio with a Single CD Player
This type of radio has a
button for setting the time.
You can set the time by following these steps:
1. Turn the ignition key to ACC/ACCESSORY or
ON/RUN. Press the
knob, located in the
center of the radio, to turn the radio on.
2. Press the
button until the hour begins flashing
on the display. Press the button a second time and
the minute begins flashing on the display.
3. While either the hour or the minute numbers are
flashing, turn the
knob, located on the upper
right side of the radio, clockwise or counterclockwise
to increase or decrease the time.
4. Press the
button again until the clock display
stops flashing to set the currently displayed time;
otherwise, the flashing stops after five seconds and
the current time displayed is automatically set.
To change the time default setting from 12 hour to
24 hour, press the
button and then the pushbutton
located under the forward arrow label. Once the
time 12H and 24H are displayed, press the pushbutton
located under the desired option to select the default.
Press the
button again to apply the selected default,
or let the screen time out
Dec 27, 2014 | 2008 Chevrolet Cobalt
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
How do you set the time? I figured out the alarm clock but can't find a way to set up the time.
Setting the Clock
1. Press and hold the HOUR button for 5 seconds (Fig. 5). The time will begin to flash
2. While the time is flashing, press the HOUR button until you reach the correct hour. Then press the
MINUTE button (Fig. 5) until you reach the correct minute.
NOTE: PM indicator will appear on the left side of the clock face for evening hours (Fig. 5). If the
PM indicator is not illuminated, the hour is set to AM. Be sure to set the time for the correct
12-hour period - AM (morning) or PM (evening).
NOTE: After 5 seconds, the time will stop flashing and it will be set.
Mar 03, 2011 | Homedics SS-4000 Clock Radio
I have the alarm clock and the time won't stop flashing, we can't put the right time. What can we do, please help, it's really anoying!
  1. Slide the Lock/Wake/Clock switch to the far right (the Clock position) to enter the clock setting mode.
  2. Press REV or FWD to set the time. Press and hold to decrease or increase the time value quickly. The ":" flashes on the display in clock setting mode.
  3. Slide the switch back to the Lock position.
Jan 29, 2011 | RCA RP5430 Clock Radio
How to install time
Press and hold Set until a little clock is displayed. Then use the forward/reverse buttons to change the time (you will see A.M. and P.M. indicators). The buttons are all on the right side of the clock radio. Then press Set again to leave the time set area. As you press Set again, you will be able to set the alarm time (Wake 1 and Wake 2) by pressing the forward/reverse buttons as well.
If any icon is flashing, press Set repeatedly until they stop.
I hope this helps.
Aug 23, 2010 | RCA RP5610 Clock Radio
How do I set the alarm? Please help! Am I supposed to do something after setting the time of the alarm? The display continues to flash the time.
To set your alarm you should be turning your Set Control (the big round button just below the Set Day button) to Alarm 1 or 2. Once you finish setting your time you should be able to turn the Set Control back to Clock and the time should stop flashing. If this does not work you may have a defective unit which you might have to take up with your retailer.
Jul 07, 2009 | Philips AJ3965 Clock Radio
Need instructions for Wharfdale ccr1cd micro clock alarm
Press the STOP/CLOCK button for about 3 seconds till the hour number flashes
use the forward and reverse buttons to set the time on the hour
press the stop/clock button again to move on to minutes numbers
use the forward and reverse buttons to set minutes
Press the stop/clock button again to complete process
Mar 25, 2009 | Audio Players & Recorders
How to set time Copy this web link and paste it into the address bar of your browser. The link will take you to the Emerson customer support clock Radio Owners manual directory. Here you can find you Type of radio and open the link and find you model. Open the model link and then you can follow the instruction given in the manual to set the clock. I hope this information helps you with your problem.
May 09, 2008 | Emerson Smartset Clock Radio
Virgin Pulse model VP-07 CD clock radio
1. To set the clock to leave the unit in standby mode. (Plug in the AC cord to a wall outlet without switching unit on). 2. Press SET button for about five seconds until AM--12:00-- stops flashing. 3. Press down TUNING button to adjust hour, and up TUNING button to adjust minute. 4. Press SET button to confirm time set.
Sep 11, 2007 | Virgin Pulse VP-07 Clock Radio
29 people viewed this question
