I'm trying to hook my PS3 up to my TCL flat screen TV with HDMI but all I get is a black line down the screen
  • Televison & ... Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 22, 2016
SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
  • 231 Answers
SOURCE: purple line down tv
tv needs repair ..possible bad buffer board or logic board bad and or possibly a bad panel ..
Posted on Mar 18, 2009
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
SOURCE: Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Posted on Dec 20, 2009
SOURCE: Insignia 42" black screen and line problem
either call the warranty or get a new t.v.
Posted on Mar 04, 2010
I have a 40" TCL TV with one black vertical line on the screen.
Your set has some board that performs the function to connect the screen to the video-generation function of the TV. Either your LED/LCD screen is failing or the video function is failing. If the set is under warranty, contact the manufacturer using the information on the warranty statement. Try using a different video input (hdmi/composite/etc) for the TV and see if you get the same line on all inputs. If there is no separate board, the next step would be to try and replace the main video board. With the prices falling on lower resolution TV's, it would probably be cheaper to replace the TV than trying a repair, if it is out of warranty. 40" 1080p TV's can be had for less than $200 at some sales (e.g. Black Friday).
Jan 14, 2015 | TCL E3010 Series LE40FHDE3010 40" LED TV...
Tcl tv sound
New 48" TCL tv. Hooked into cable box via hdmi cable from hdmi 2 per instructions. Problem is no sound. Screen looks great volume bar shows volume etc. Any ideas before I take it back to SAMs.
Jan 05, 2014 | Televison & Video
PS3 set up with HDMI but shuts off then comes on and black screen
have you been tried to hooked up with other source in the hdmi port just to ensure if the cause is with in the tv itself or due to the ps3.
Nov 01, 2012 | Protron PLTV-3750 Television
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
PS3 problems At home I have a new samsung hd 1080p TV that I normally use for my PS3. I will be in a hotel outa town for the next couple of days and I wanna watch a movie using my PS3. In my...
I had the same problem, stuck in a hotel room for 2 days. When I held down the button, next time I turned it on, I got the same prompt with using HDMI output, said yes, and screen went black. However, a screen then came up asking if I could see the image or not, but it has a 30 second time limit before it saves those setting, you have to click "No" on this screen, and it will drop the resolution to 780p instead of 1080 and it should work! Make sure you're paying attention so you don't miss the screen!
Nov 13, 2010 | Sony Playstation 3 (PS3) Console
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
Try this
1. Turn ON TV
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
HDMI causes red lines (static?) on screen
im having the same problem to fix it i unhook my cable box (the video cables and the hdmi inputs to the tv) this stops the lines--try just the ps3 hooked to the tv and no other devices this should solve the problem--must be getting interference from some device
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
