Question about Boating
I need the torque specs for the rocker arms and the head bolts on a 2.5 inboard motor on a 1986 Searay Seville
    Genius:
  • 1,071 Answers
Headbolts are 85 foot pounds rockers are adjusted according to wear
Posted on Jul 21, 2009
Torque specs 2003 olds silhouette rocker arm 3.400
Here is a suggested updated torque spec for this engine's rocker arm bolts;
Rocker arms
Step one: Torque to 11 ft lbs then tighten an additional 90 degrees of bolt head rotation. Some guys don't fuss with the torque specs and just get them good and tight. Either way, be careful, as the heads are aluminum. You do not want to over tighten these bolts
Oct 07, 2016 | 2003 Oldsmobile Silhouette
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Rocker arm pivot torque for olds cutlass 1987 307
Oldsmobile Torque Specs - GbodyOlds.com
www.gbodyolds.com/forum/showthread.php?754-Oldsmobile-Torque...
Feb 7, 2013 - 2 posts - ‎2 authors Oldsmobile Small-Block Engines Cylinder Head Bolts (1/2in. bolt) 130 ft. lbs. Cylinder Head ... Rocker Arm Pivot Bolt 25 ft. lbs. Rod Bearing ...
Rocker Arms - AutoZone
www.autozone.com/...Cutlass...1987.../Rocker-Arms/_/P-0900...
AutoZoneGM Cutlass RWD 1970-1987 Repair Guide ... To remove the rocker arms from the shaft, the nylon arm retainers must be removed. ... 7: Engine valve system, 260, 307, 350, 403 Oldsmobile built engines ... Unfasten the two bolts that attach the rocker arm pivot to the cylinder head. ... Torque the retaining bolts to 25 ft. lbs.
Dec 01, 2015 | 1987 Oldsmobile Cutlass Salon
Torque specs for rocker arms
The 12mm head bolts torque to 15 ftlbs.
the 10mm head bolts torque to 9 ftlbs.
crosshatch pattern for the sequence.
Jul 02, 2014 | 1992 Honda Accord
I need the engine torque specs for 99 chevy malibu. like the head bolt torque sequence and rocker bolt torque sequence
99 chevy malibu v6 3.1 engine, head bolt torque is-- 98 through 2001 is step1- 37 foot lbs, step 2- rotate an additional 90 degrees (1/4 turn). the rocker arm bolts are 168-in. lbs.
Mar 12, 2010 | 1999 Chevrolet Malibu
I need torque specs on 93 dodge 360 ..heads, rocker assembly and torque sequence
Cylinder Head Bolt 5.9L
Step 1 - 50 ftlb
Step 2 - 105 ftlb
Step 3 - Recheck At 105 ftlb
Tightening sequence
Rocker Arm Bolt
5.9L - 17 ftlb
Jan 23, 2010 | 1993 Dodge Ramcharger
I have 4.9L6 need torque specs for cylinder head
for cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
Dec 05, 2009 | 1988 Ford F 150
Boating Logo
120 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
