Question about PRINTER Office Equipment & Supplies
My printer won't print it does not say any thing
  • kakima Dec 22, 2016
    Hi Anne Kruger Lambert, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
After installing Mountain Lion, my Lexmark Pro901 won't print and scan. Help
Apparently Apple have not included the Driver from Lexmark, so you have to use their own driver to make thing work. Lexmark Tech support will talk you through it.
Aug 16, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
Printer cartridge alignment checks
Is this with new cartridges or refilled?
If refilled, the nozzles may have become blocked which isn't the easiest thing to clear. If new cartridges, take them back for a replacement at the store and try again with new ones
Dec 12, 2011 | HP LaserJet 1320 Printer
Won't print it always says document in queue
This sometimes happens if a print job freezes before, or during the print. I would suggest two things. Open up your print que, which you should be able to access from the bottom right hand side of your screen in your task bar. Right click, and open print que. If there is a print job in the que that says printing, try to right click on the job and cancel it. If this does not work and you have not done so already, restart your computer and your printer! Go back into the que if you have to and if the job is still there, right click and cancel job again. Then, retry printing a something different from your printer. This should solve your problem.
Sep 20, 2011 | Canon Pixma MX420 All-In-One Printer
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
I have a HP Officejet 4500 printer, and when I try to connect it, via ethernet cord, to my laptop, it won't connect. I did download and install via installation CD, so it's installed. Mind you I...
Hi ericcris10se
If you have trouble with the ethernet connection , try USB . If it also fails there , your device is defective or you have a driver issue . Make sure you have installed the correct driver and prefer the download file to the cd version :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351106&lc=en&cc=us&dlc=en&lang=en&cc=us
Best regards,
fanaudi
Aug 14, 2011 | HP OfficeJet 4215 All-In-One InkJet...
I Have An HP D145 Printer That Won't Print Some Online Coupons Or Will Only Print Portions Of Them. Any Advice? Thank You
Most likely this is an issue with the way the website is displaying the coupon. Check to see if there is an option to print coupon. You might also try to create a PDF copy of the coupon and then printing the PDF document. Finally, one other thing you could try is to take a screen capture of the coupon, save as an image file or PDF and then print as an image or PDF. Hope this helps.
Jul 11, 2011 | HP OfficeJet d145 InkJet Printer
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
My printer won't print.
There are different things to consider if your printer is not printing your document
1. Check if the printer is on
2. Check if the cable from your printer is properly connected to the tower or your pc.
3. Check if your ink cartridges are not empty ( note: most printers will not print if one of the ink cartridge is empty)
4. Check for the error message that appears on your screen every time that your printer fails to print the document ( note: this will help you isolate problem)
5. You can use this link to download the manual for your printer ( this include steps to check your printer settings )
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=303753
May 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
Printing problem
how can we print a booklet on this printer
Mar 15, 2009 | Lexmark X1240 All-In-One InkJet Printer
22 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
murray greenberger
Level 1 Expert
John Hong
John Hong
rfredey
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
