Question about Hardware & Accessories
I wish to replace the battery in my MTD8 timer. I have charged for 8 hrs== but no joy. How do I get a circuit diagram of the PC Board in order to be able to identify the battery ?
This unit has been in store for a long time===looks as if the battery is dead. No indication at all when plugged in. Should it show that the unit is charging ? I have opened up and now able to access the PC board. Is the battery component JOX-14f IF SO WHERE WOULD I OBTAIN ? Could the problem be somewhere else ?
SOURCE: Casio LK-30 Key Board Piano
I have the same problem. I was thinking one solution for us, but I don't like it might be to solder the power supply on and skip that female plug entirely. To do that, you cut the male end off the transformer/power supply wire (if you don't want to ruin your transformer/power supply you can buy another power supply at Best Buy for $10 - Dynex DX-C1109). Then strip the ends from each wire from the power supply so you have some bare wire showing on each wire. One goes on the spiral thing sticking up from the JCM470 board, the other goes anywhere you want on the red wire coming from the battery compartment. You should test before you solder to make sure you the proper one on the proper wire and that you therefore have power to the unit and it makes a sound. But its a sloppy fix. While it should work perfectly, the power pack then can't be changed unless you solder and unsolder it each time. Another solution is to find a broken LK-30 or LK-33 and rob the circuit board if it still works on the parts machine. Trouble is if you find one and its not near you it costs some money to ship these. At some point its just easier to buy a used one on Ebay or craigslist.com, I guess.
Posted on Feb 24, 2008
  • 326 Answers
SOURCE: Dead Toshiba A100 laptop computer
In order to replace the power jack in your laptop you’ll have to remove the jack from the motherboard as I explained in the previous post: Replacing DC power jack.
While removing the jack you can accidentally pull out the internal copper coating (I’ll call it a sleeve) from the inside of the “+” terminal as it shown on the picture below.
The internal copper sleeve has been removed and cannot be installed back. If you solder the power jack back on the motherboard without this sleeve it might work but the connection between the “+” lead and motherboard will not be reliable.
In the following guide I explain how to fortify a damaged power jack connection. You can use this repair technique in some laptops with similar power jacks.
Laptop is dead. How to troubleshoot the problem.In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack. Check out thisguide for fixing laptop power jack.
Posted on Jan 12, 2009
  • 32 Answers
SOURCE: battery charger on board doesn't work. Replaced everything, stil
try replacing the battery fuse
Posted on Jul 13, 2009
  • 103 Answers
SOURCE: Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
Posted on Nov 10, 2009
issken
  • 1472 Answers
SOURCE: dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Posted on Jan 11, 2010
My Invacare Wheelchair w/tilt & recline doesn't fully charge. I'm on the third new battery change & still same issue. Could it be my circuit board. Could it be me joy stick?
In any device that has a charging circuit that circuit can fail to charge batteries after a time. Ypu could have an electronics technician check what happens in the charging circuit. As you have changed three batteries the fault must lie elsewhere, as you have deduced.
Support Surface Resources
Support Surfaces
Jul 04, 2015 | Invacare Health & Beauty
How to set the timer
MTD8 is 240Volt din rail timer max load 15 amps
Copy following link to identify timer and download manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html#TE22
Oct 17, 2012 | Major Hardware & Accessories
Low Battery Life.
You may have a bad battery. These batteries also lose capacity over time and over the number of charge/recharge cycles.
In addition, many batteries need to be fully discharged about once a month in order to keep themselves calibrated.
Once you lose the ability to get a complete charge, you need to replace the battery.
Feb 15, 2012 | Computers & Internet
Battery will charge but radio will not turn on iv changed fusse inside but no joy
There are two fuses, one on the power supply board and another on the battery holder board.
Check to see that power is going through the switch on the volume control.
Check to see that the radio pc board is getting power.
Look here for parts diagrams and user manual:
http://servicenet.dewalt.com/Products/Detail/DC011
Good luck from Detroit, MI.
Oct 05, 2011 | Dewalt DC011 AM/FM Radio
Acer travelmate 5720 battery stopped taking charge, was told battery would be faulty, installed new battery but problem prevails
either ac adapter is dead or the power socket of the notebook is defective and power is no longer charging the battery. if you have a multimeter, test the ac adpter for power.if thers is power then wiggle jack maybe temp charge. i can fix, 7863893088
Aug 12, 2010 | Acer Aspire One PC Notebook
My mobile phone charger broke and I couldn't charge it for two weeks. After ordering a similar model from China with the same charger, the phone still didn't want to charge and I can't turn it on.
replace the battery and see. when the battery is drained 100% and kept it drained for longer time period they never get charged after that but in ur case 2 weeks is too early for a battery to do that. Keep it connected for atleast 8 hrs and see , it does not work after 8 hrs then u sure need a new battery.
thanks
Aug 04, 2010 | Cell Phones
My toshiko trimmer is not getting charged, even after charging for 6 hrs it works hardly for 5 seconds and stops.what should i do?
mcdevito75 here, Sounds like the batteries won"t take a charge anymore. Refer to the Toshiko website at Tosiko.com for battery replacement, however at times the batteries cannot be replaced as they are attached to a circuit board and, you"d need to replace the shaver.
Jun 21, 2010 | Toshiko Shaver/Trimmer Set Electric Shaver
Kenmore model 596.52673202 refrigerator not cooling or freezing
the defrost should be controlled by a timer every 10 hrs or so,it is usually in the bottom of the fridge by the compressor,it has a small motor that turns the timer,they burn out
Jul 21, 2009 | Kenmore 53642 / 53644 Side by Side...
I have an MTD8 timer, that fits into my main electrical board
MTD8 Timer - Instruction manual
1. This timer has a total of 8 ON / OFF programs.
2. MANUAL ON / AUTO / MANUAL OFF for easy setting.
3. Switchable 12 / 24 hour mode.
4. 16 timer combinations are available as follows:
Monday
Tuesday
Wednesday
Thursday
Friday
Saturday
Sunday
Mo, Tu, We, Th, Fr, Sa, Su
Mo, Tu, We, Th, Fr
Mo, We, Fr, Su
Mo, We, Fr
Tu, Th, Sa
Mo, Tu, We
Th, Fr, Sa
Sa, Su
Initial operation:
1. When the timer is first connected to mains power, it will take up to 12 hours to charge the internal battery.
2. The settings can be defaulted by depressing the R (reset) button.
Setting Current Time.
1. Press the C+ (clock) button and hold, then simultaneously press the W+ (week) button until the actual day is displayed. Continue by pressing the H+ (hour) or M+ (minute) button until the current hour or minute is displayed. When setting, the W+, H+ and M+ buttons can be held down for rapid forward counting.
2. Release both buttons. The weekday and time will be set according to your selections.
3. To set incorrect time (etc.) repeat the settings.
Settings for programs:
1. Press the Timer button (Clock) and release. The first ON setting can now be made.
2. Press the W+ button to set the day or blocks of days. Select the ON time by pressing the H+ button and then the M+ button.
3. Press the Timer button (clock symbol) again to finish the first ON setting and enter into the first OFF setting. Repeat step 2 to set the first OFF setting.
4. Press the Timer button again to finish the first OFF setting and enter into the second ON setting. Repeat steps 2 and 3 to program the remaining settings.
When setting block dates, the ON and OFF times apply to all dates in the block.
I.E. Selecting block Mo, Tu, We, Th, Fr, Sa, Su and setting ON to 10:00 and OFF to 16:00 means that the selected times automatically apply to all the indicated days in that block.
Specifications: 230Vac 50 or 60Hz. 16A Inductive load. 20A Resistive load.
Battery backup >100 hours. Accuracy: +/- 1 minute per month. Temp: -10 to +40 deg C.
Apr 18, 2009 | Hardware & Accessories
Hardware & Accessories Logo
137 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
